samsung e2652 problem in flashing dead mobile when right not flashing start Code: UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 |
1 Attachment(s) i have flashed sam e2652w with hwk all ok but my problem not solved phone display when powering on a pc cable and phone and stil lik this after flash the same problem . plz help |
you remowe usb cable too fast after flashing ! |
just re flash once more.. try and try in SW... |
post full log of flashing process. and you use 2.2.0.1 ? |
problem solved , i flashed the phone wit other vers and it is a live now ,thanks averybody UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., S/n: 74479 HID: Exxxxxxxxxxxxxxxx HWK: A1.04-PRO1 Licence: True LogFile: .\_!_LOG\74479_10082011_124611_LOG.txt Loaded Settings from: Sams.ini Regions : Arabic Language: ar,en,fr(fa,ur) Release : 2011 June Rev: 1 Regions : Austria,Benelux,France,Germany,Hungary,Italy,Spain ,UK Language: de,en,es,fr,hu,it,nl,pt(cs,da,el,fi,no,pl,sl,sv,tr ) Release : 2011 February Rev: 4 If used non Auto-Ignition cable, press Power-On button IF_SBL: XGOLD213, Ok IF_EBL: 6180_Bootloader_10.0_MKEYSKEY.10.0, Mode: BB BAUD_R: 921600 FL_ID : EC000822, Samsung K8F5615ETM 256Mb Erase Area: 0x00000000 - 0x0FFFFFFD, Erased: 00:02 MSL Patched OK: 00:00 E2652WXXKB4_BIN.fls FLASH BUNDLE: Flash File: CATFISH.fls Erase Area: 0x40040000 - 0x41F7FFFE, Erased: 01:10 Write Area: 0x40040000 - 0x41B24DFA, Written: 07:44 E2652WXXKB4_psi_flash.fls FLASH BUNDLE: Flash File: dwdtoolsrc/bootcore/make/.output/XMM6180_EHS2AGR_CATFISH_ROU_TETHYS/fls/psi_flash.fls Erase Area: 0x40000000 - 0x4003FFFE, Erased: 00:00 Write Area: 0x40000000 - 0x4002986A, Written: 00:02 E2652WXXKB4_CDS.fls FLASH BUNDLE: Flash File: CATFISH.fls Erase Area: 0x41F80000 - 0x41FFFFFE, Erased: 00:01 Write Area: 0x41F80000 - 0x41FE19EE, Written: 00:06 E2652WOXEKB2_CSC.dffs FLASH BUNDLE: Flash File: temp_GT-E2652W_OXE.dffs Erase Area: 0xA0C80000 - 0xA7A3FFFE, Erased: 00:00 Write Area: 0xA0C80000 - 0xA26F269A, Written: 07:59 E2652WXXKB4_UI_IMAGE.fls FLASH BUNDLE: Flash File: temp_UI_IMAGE.fls Erase Area: 0xA0080000 - 0xA0C7FFFE, Erased: 00:00 Write Area: 0xA0080000 - 0xA07F3E0E, Written: 02:09 ShutDown Done All Done, Time: 21:21 Make [Reset MMI] or Use *2767*3855# at First Start ! |
you flash by cable usb or rj45 for hwk?? thank |
i have face this problem thanks for information yahia ali |
1 Attachment(s) remove this both tick and flash its work 100%%% work |
E2652 flashing proceedures Quote:
http://forum.gsmhosting.com/vbb/f453...0/#post7850948 |
1 Attachment(s) E2652W Flashed and 100% OK Code:
use spt box i hope solve ur problam... |
Insert USB Cable to Switched Off Phone IF_USB: XGOLD21x IF_SBL: XGOLD213, Ok IF_EBL: 6180_Bootloader_10.0_MKEYSKEY 10.0, Mode: BB FL_ID : EC000822, Samsung K8F5615ETM 256Mb Erase Area: 0x00000000 - 0x0FFFFFFD, Erased: 00:02 MSL Patched OK: 00:00 E2652WJPKH1_BSY.fls FLASH BUNDLE: Flash File: CATFISH.fls Erase Area: 0x40040000 - 0x41F7FFFE, Erased: 01:18 Write Area: 0x40040000 - 0x41C3046A, Written: 00:55 E2652WJPKH1_psi_flash.fls FLASH BUNDLE: Flash File: dwdtoolsrc/bootcore/make/.output/XMM6180_EHS2AGR_CATFISH_ROU_TETHYS/fls/psi_flash.fls Erase Area: 0x40000000 - 0x4003FFFE, Erased: 00:00 Write Area: 0x40000000 - 0x4002986A, Written: 00:00 E2652WJPKH1_CDS.fls FLASH BUNDLE: Flash File: CATFISH.fls Erase Area: 0x41F80000 - 0x41FFFFFE, Erased: 00:01 Write Area: 0x41F80000 - 0x41FE1A92, Written: 00:00 E2652WOJPKH1_CSC.dffs FLASH BUNDLE: Flash File: temp_GT-E2652W_OJP.dffs Erase Area: 0xA0C80000 - 0xA7A3FFFE, Erased: 00:00 Write Area: 0xA0C80000 - 0xA2F225E6, Written: 01:23 E2652WJPKH1_UI_IMAGE.fls FLASH BUNDLE: Flash File: temp_UI_IMAGE.fls Erase Area: 0xA0080000 - 0xA0C7FFFE, Erased: 00:00 Write Area: 0xA0080000 - 0xA0ADBB52, Written: 00:17 ShutDown Done All Done, Time: 04:20 Make [Reset MMI] or Use *2767*3855# at First Start ! Factory Reset Done, Wait for Product Restart Software: E2652WJPKH1/E2652WOJPKH1 Regions : Arabic Language: ar,en,fr(fa,ur) Release : 2011 August Rev: 1 IME1: 354661-04-59****-3 IME2: 354662-04-59****-1 S/N : RQ2BC11037 BTID: 8425DB-565991 WiFi: 8425DB-565992 ULCK: 00000000 Level Of Lock: 00h NCK : 00000000 [#0111*00000000#] SCK : 00000000 [#0121*00000000#] SPCK: 00000000 [#0133*00000000#] PCK : 11021979 [#0141*11021979#] MCK : 54684280 [#0199*54684280#] |
