Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 07-10-2011, 17:29   #1 (permalink)
DIN231080's Avatar
Member: 523792
Thanks Meter: 96
samsung e2652 problem in flashing
dead mobile
when right not flashing start
UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10
UFS_USB V2.8 (c) SarasSoft 2007., S/n: 96593
HID: 8xxxxxxxxxxxxxx
HWK: A1.04-PRO1
Licence: True
LogFile: .\_!_LOG\96593_71020119_4707_LOG.txt
Loaded Settings from: Sams.ini
If used non Auto-Ignition cable, press Power-On button
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
IF_SBL: XGOLD213, Ok
IFEBL_ERR_RSP: 1F5A
IFEBL_ERR_RSP: 1F5A
IFEBL_ERR_RSP: 1F5A
Old 08-09-2011, 23:53   #2 (permalink)
yahia ali's Avatar
Member: 206173
Thanks Meter: 169
i have flashed sam e2652w with hwk all ok but my problem not solved phone display when powering on a pc cable and phone and stil lik this after flash the same problem . plz help
Old 08-10-2011, 00:19   #3 (permalink)
Member: 904530
Thanks Meter: 517
you remowe usb cable too fast after flashing !
Old 08-10-2011, 00:25   #4 (permalink)
Member: 812397
just re flash once more.. try and try in SW...
Old 08-10-2011, 00:31   #5 (permalink)
Member: 904530
Thanks Meter: 517
post full log of flashing process.
and you use 2.2.0.1 ?
Old 08-10-2011, 13:18   #6 (permalink)
yahia ali's Avatar
Member: 206173
Thanks Meter: 169
problem solved , i flashed the phone wit other vers and it is a live now ,thanks averybody
UFS_USB V2.8 (c) SarasSoft 2007., S/n: 74479
HID: Exxxxxxxxxxxxxxxx
HWK: A1.04-PRO1
Licence: True
LogFile: .\_!_LOG\74479_10082011_124611_LOG.txt
Regions : Arabic
Language: ar,en,fr(fa,ur)
Release : 2011 June Rev: 1
Regions : Austria,Benelux,France,Germany,Hungary,Italy,Spain ,UK
Language: de,en,es,fr,hu,it,nl,pt(cs,da,el,fi,no,pl,sl,sv,tr )
Release : 2011 February Rev: 4
IF_EBL: 6180_Bootloader_10.0_MKEYSKEY.10.0, Mode: BB
BAUD_R: 921600
FL_ID : EC000822, Samsung K8F5615ETM 256Mb
Erase Area: 0x00000000 - 0x0FFFFFFD, Erased: 00:02
MSL Patched OK: 00:00
E2652WXXKB4_BIN.fls FLASH BUNDLE:
Flash File: CATFISH.fls
Erase Area: 0x40040000 - 0x41F7FFFE, Erased: 01:10
Write Area: 0x40040000 - 0x41B24DFA, Written: 07:44
E2652WXXKB4_psi_flash.fls FLASH BUNDLE:
Flash File: dwdtoolsrc/bootcore/make/.output/XMM6180_EHS2AGR_CATFISH_ROU_TETHYS/fls/psi_flash.fls
Erase Area: 0x40000000 - 0x4003FFFE, Erased: 00:00
Write Area: 0x40000000 - 0x4002986A, Written: 00:02
E2652WXXKB4_CDS.fls FLASH BUNDLE:
Erase Area: 0x41F80000 - 0x41FFFFFE, Erased: 00:01
Write Area: 0x41F80000 - 0x41FE19EE, Written: 00:06
E2652WOXEKB2_CSC.dffs FLASH BUNDLE:
Flash File: temp_GT-E2652W_OXE.dffs
Erase Area: 0xA0C80000 - 0xA7A3FFFE, Erased: 00:00
Write Area: 0xA0C80000 - 0xA26F269A, Written: 07:59
E2652WXXKB4_UI_IMAGE.fls FLASH BUNDLE:
Flash File: temp_UI_IMAGE.fls
Erase Area: 0xA0080000 - 0xA0C7FFFE, Erased: 00:00
Write Area: 0xA0080000 - 0xA07F3E0E, Written: 02:09
ShutDown Done
All Done, Time: 21:21
Make [Reset MMI] or Use *2767*3855# at First Start !
Old 08-11-2011, 18:26   #7 (permalink)
Member: 1195046
you flash by cable usb or rj45 for hwk??
thank
Old 08-15-2011, 12:54   #8 (permalink)
DIN231080's Avatar
Member: 523792
Thanks Meter: 96
this happening do to wrong or missing file error select expropriate file flash
Old 10-17-2011, 08:51   #9 (permalink)
RAHMAN007's Avatar
Member: 915625
Thanks Meter: 47
i have face this problem
thanks for information
yahia ali
Old 10-17-2011, 16:17   #10 (permalink)
Member: 345808
Thanks Meter: 21
remove this both tick and flash its work 100%%% work
Old 11-01-2011, 14:32   #11 (permalink)
Member: 56369
Thanks Meter: 47
E2652 flashing proceedures
thank
http://forum.gsmhosting.com/vbb/f453...0/#post7850948
Old 11-09-2011, 10:42   #12 (permalink)
allal123's Avatar
Member: 192681
Sonork: 100.106870
Thanks Meter: 5,082
E2652W Flashed and 100% OK
IF_EBL: 6180_Bootloader_10.0_MKEYSKEY 10.0, Mode: BB
BAUD_R: 921600
E2652WJPKH1_BSY.fls FLASH BUNDLE:
Erase Area: 0x40040000 - 0x41F7FFFE, Erased: 01:12
Write Area: 0x40040000 - 0x41C3046A, Written: 07:54
E2652WJPKH1_psi_flash.fls FLASH BUNDLE:
E2652WJPKH1_CDS.fls FLASH BUNDLE:
Write Area: 0x41F80000 - 0x41FE1A92, Written: 00:06
E2652WOJPKH1_CSC.dffs FLASH BUNDLE:
Flash File: temp_GT-E2652W_OJP.dffs
Write Area: 0xA0C80000 - 0xA2F225E6, Written: 10:13
E2652WJPKH1_UI_IMAGE.fls FLASH BUNDLE:
Write Area: 0xA0080000 - 0xA0ADBB52, Written: 02:57
ShutDown Done
All Done, Time: 24:02
The Following 2 Users Say Thank You to allal123 For This Useful Post:
Old 01-12-2012, 14:15   #13 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 11,979
brother check this .
http://forum.gsmhosting.com/vbb/f200...asher-1413209/
azimbahar
Old 01-12-2012, 14:18   #14 (permalink)
VC_INDIA's Avatar
Member: 1236722
Sonork: 100.1601546
Thanks Meter: 4,180
Originally Posted by DIN231080 View Post
dead mobile
HWK: A1.04-PRO1
Licence: True
IFEBL_ERR_RSP: 1F5A
IFEBL_ERR_RSP: 1F5A
IFEBL_ERR_RSP: 1F5A
use spt box i hope solve ur problam...
Old 03-15-2012, 10:33   #15 (permalink)
allal123's Avatar
Member: 192681
Sonork: 100.106870
Thanks Meter: 5,082
why SPT BOX ???
Insert USB Cable to Switched Off Phone
IF_USB: XGOLD21x
Erase Area: 0x40040000 - 0x41F7FFFE, Erased: 01:18
Write Area: 0x40040000 - 0x41C3046A, Written: 00:55
Write Area: 0x40000000 - 0x4002986A, Written: 00:00
Write Area: 0x41F80000 - 0x41FE1A92, Written: 00:00
Write Area: 0xA0C80000 - 0xA2F225E6, Written: 01:23
Write Area: 0xA0080000 - 0xA0ADBB52, Written: 00:17
ShutDown Done
All Done, Time: 04:20
Factory Reset Done, Wait for Product Restart
Software: E2652WJPKH1/E2652WOJPKH1
Regions : Arabic
Release : 2011 August Rev: 1
IME1: 354661-04-59****-3
IME2: 354662-04-59****-1
S/N : RQ2BC11037
BTID: 8425DB-565991
WiFi: 8425DB-565992
ULCK: 00000000
Level Of Lock: 00h
NCK : 00000000 [#0111*00000000#]
SCK : 00000000 [#0121*00000000#]
SPCK: 00000000 [#0133*00000000#]
PCK : 11021979 [#0141*11021979#]
MCK : 54684280 [#0199*54684280#]
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.29554 seconds with 10 queries
