Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 04-15-2006, 10:23   #1 (permalink)
Member: 16927
Thanks Meter: 134
SAMSUNG X660 unlock problem !! HELP
Hi
I have Samsung X660 and cable E860 for him. Whem i press Mobile info (with or without battery) i have message "Failed to enter Test Mode", any help? any solution?
br,
fingusio
Old 04-15-2006, 11:24   #2 (permalink)
afra.com's Avatar
Member: 126227
Thanks Meter: 23
use Samsung E860 com cable & unlock with winimei x660 all will be ok
afra
Old 04-15-2006, 11:28   #3 (permalink)
Member: 16927
Thanks Meter: 134
If i have cable for COM i will do it. I haven't it. Today I buy cable for Twister but not working. I think its cable problem.
br,
fingusio
Old 04-15-2006, 12:39   #4 (permalink)
..::Mr999::..'s Avatar
Member: 154749
Sonork: 100.92483
Thanks Meter: 1,048
br,
fingusio
well i think problem in phones point ..well try to use another cable if u got cable problem...
Old 04-15-2006, 12:47   #5 (permalink)
garfild's Avatar
Member: 51104
Thanks Meter: 6
br,
fingusio
cable is not problem
conect phone with batery, press unlock and press ON in phone
try bro
regards
Old 04-15-2006, 12:55   #6 (permalink)
yassinov®'s Avatar
Member: 51694
Thanks Meter: 5
Arrow UFS Simple Pinouts Way !
Here's the main mail RJ45 connector of Ufs Cables !
Repair / Buld your Cables !!
About X660/X660v are same pinouts of E860V
Keyb Up
660/v-E860/v
1---------------------------18
[8-11 = GND]
[9 = RX]
[10 = TX]
That's All !
Old 04-15-2006, 12:56   #7 (permalink)
Member: 16927
Thanks Meter: 134
try bro
regards
Not working. When I do as you said, phone just power on and again "Failed to enter Test Mode"
br,
fingusio
Old 04-15-2006, 13:01   #8 (permalink)
Member: 16927
Thanks Meter: 134
Post
Keyb Up
660/v-E860/v
[8-11 = GND]
[9 = RX]
[10 = TX]
That's All !
I open the cable, and there is as you said. But i found other schematics, on http://forum.gsmhosting.com/vbb/atta...8&d=1142287880
And other by Odia (in attached file). Somebody can confirm thats schematics works? I wouldn't makes any changes, I just send cable to my seller and he give me new.
br,
fingusio
Old 04-15-2006, 13:04   #9 (permalink)
XisiX's Avatar
Member: 37090
Thanks Meter: 42
UFSx E860 cable schematic: http://forum.gsmhosting.com/vbb/show...5&postcount=16 (posted by Odia, yes)
Try Mobile Info first, it must works.
Direct unlock with battery inside (no need to press any key) takes 1 second. Tested.
Old 04-15-2006, 13:10   #10 (permalink)
yassinov®'s Avatar
Member: 51694
Thanks Meter: 5
Arrow
br,
fingusio
I know that exist already a Pdf shematic from UFs support !
This is a simple shem ! tested 100% work !
Note : that u must work with battery here [Pw charge pinouts not included]
Old 04-15-2006, 13:43   #11 (permalink)
Windziarz's Avatar
Member: 18406
Thanks Meter: 84
br,
fingusio
this scheme is 100% working
Old 04-15-2006, 19:22   #12 (permalink)
Member: 16927
Thanks Meter: 134
OK so I send this cable to seller and then he looks inside and repair, I dont repair myself because I destroy it hyhy
br,
fingusio
Old 04-15-2006, 20:59   #13 (permalink)
Member: 10600
Hello mate!
Try this:
-click "Info" then connet cable to phone and wait,
* if not working do this:
-disconnet battery from phone to avoid charging and power on on phone-also you can flash most Samsung phones without battery on Saras-Box..
-then click "info" ...
Old 04-15-2006, 21:11   #14 (permalink)
BoOzer665's Avatar
Member: 44186
Sonork: 100.108965
Thanks Meter: 65
yu need 2 unlock it as c200 ...chose c200 and unlock it using ufs e860 cable .. schimatic of the cable attached
Old 04-15-2006, 21:52   #15 (permalink)
deYo's Avatar
Member: 52325
Sonork: GSM ELECTRONIC
Thanks Meter: 18
br,
fingusio
Hi,
If you have "teleway" cable please change position brown and grey wire(pin 9 and 10) and cable work perfect.
WBR
deyo
Samsung t469 unlock problem help me now wiliam UST Pro II 11 07-13-2010 17:23
samsung t201g unlock problem help me ik_tel UST Pro II 2 01-12-2010 13:42
Samsung X660 imei = 0000000000 help! alvinteh HWK 1 05-29-2009 11:12
Samsung C260 unlock problem. HELP URGENT!!! fingusio NSPRO 2 10-25-2007 15:04
HWK Samsung X660 unlock? anjella HWK 11 06-29-2006 12:56
Page generated in 0.26808 seconds with 10 queries
