12-23-2019, 13:18 | #32 (permalink) |
No Life Poster Join Date: Apr 2014 Location: tripoli,libya Age: 36
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | PROBLEM ? what is this i use offline set up 2 years ago till 2 weeks ago " now " Authentication stage error: Server reported error: No more upgrade logs. Please contact your reseller! |
02-22-2020, 08:25 | #39 (permalink) |
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | Guys is there trusted way to install it offline all pervious ways is not successful Sent from my INE-LX1 using Tapatalk |
06-29-2020, 07:28 | #40 (permalink) |
Insane Poster Join Date: Dec 2009 Location: GrahaFlasher
Member: 1194110 Status: Offline Thanks Meter: 113 | UFS Panel 2.3.0.9 Tested http://www.mediafire.com/file/3lp4nm804mfqj0z/%255BGrahaFlasher.COM%255D_UFS_PANEL_2.3.0.9.rar/file |
The Following User Says Thank You to [aNt] For This Useful Post: |
07-01-2020, 21:39 | #41 (permalink) | |
Freak Poster Join Date: Apr 2011 Location: ndola,zambia
Member: 1564630 Status: Offline Sonork: the blackchinese Thanks Meter: 18 | Quote:
07-31-2020, 12:52 | #44 (permalink) |
Registered User Join Date: Sep 2005 Location: Abuja nigeria
Member: 185010 Status: Offline Sonork: alias-albertino Thanks Meter: 170 | please someone should tell me is the server down ? I cant download the setup everything about my box is ok App: UFSx (HWK) Control Panel v 2.3.0.9 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 Box: 1 Location: 289 Serial: 98669 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 98669 HID: E8C53E1F4160005B, HWK: A1.04-PRO1 LIC: True BoxStat : Ok Box: 1 Location: 289 Serial: 98669 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 98669 HID: E8C53E1F4160005B, HWK: A1.04-PRO1 LIC: True BoxStat : Ok All is Ok, not Need to Update Box or Support |
08-01-2020, 17:30 | #45 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 237256 Status: Offline Thanks Meter: 91 | [QUOTE=albert maren;14166986]please someone should tell me is the server down ? I cant download the setup everything about my box is ok App: UFSx (HWK) Control Panel v 2.3.0.9 by SarasSoft Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 Box: 1 Location: 289 Serial: 98669 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 98669 HID: E8C53E1F4160005B, HWK: A1.04-PRO1 LIC: True BoxStat : Ok Box: 1 Location: 289 Serial: 98669 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 98669 HID: E8C53E1F4160005B, HWK: A1.04-PRO1 LIC: True BoxStat : Ok All is Ok, not Need to Update Box or Support[/QUO Albert you are almost done. Open support panel and do CHECK AND NEXT INSTALL/AUTH Your result should be: Paths Updated Software Authorised Once you get the above result know that your license has been dropped in to your pc registry. Next manually install software by unzipping(UFS3 PANEL 2.7.0.8 AND ALL SOFTWARE) into the path PROGRAME FILE/NOKIA/PHOENIX/PRODUCT and the second one PROGRAMME FILE/SARASOFT/UFS Now run any software of your choice and it will connect and work. |
The Following User Says Thank You to pastor good For This Useful Post: |
