08-01-2020, 17:35 | #46 (permalink) | |
No Life Poster Join Date: Feb 2006
Member: 237256 Status: Offline Thanks Meter: 91 | Quote:
Albert you are almost done. Open support panel and do CHECK AND NEXT INSTALL/AUTH Your result should be: Paths Updated Software Authorised Once you get the above result know that your license has been dropped in to your pc registry. Next manually install software by unzipping(UFS3 PANEL 2.7.0.8 AND ALL SOFTWARE) into the path PROGRAME FILE/NOKIA/PHOENIX/PRODUCT and the second one PROGRAMME FILE/SARASOFT/UFS Now run any software of your choice and it will connect and work. | |
08-01-2020, 17:43 | #47 (permalink) |
Member: 237256 Status: Offline Thanks Meter: 91 | Make sure the UFS3 PANEL AND ALL SOFTWARE is not put into the paths (programme file/sarasoft/ufs) and Programme file/Nokia/Phoenix/Product (I mean leave it empty) untill you have gotten the result of Paths Updated and Software Authorised before you unzip them into the two folders, else you have negative result when you click INSTALL/AUTH. You can also manually create the path before clicking CHECK BOX and next INSTALL/AUTH but must he left empty to enable you receive your license first. Else it will see them as unathorised softwares that you need to reinstall HWK. |
08-01-2020, 17:51 | #48 (permalink) |
Member: 237256 Status: Offline Thanks Meter: 91 | Use this, it works. UFS3 PANEL 2.7.0.8 AND ALL SOFTWARE Dont do update SOFTWARE on PANEL 2.7.0.8 after you get successful result PATHS UPDATED and SOFTWARE AUTHORISED. Do the rest many with the software from the above link. |
