Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 12-21-2019, 14:31   #31 (permalink)
Member: 1092417
Sonork: 100.1645946
Thanks Meter: 45
same problem. i can't use my box! any solution?
Old 12-23-2019, 13:18   #32 (permalink)
helpo's Avatar
Member: 2175357
Sonork: QQ:2157039171
Thanks Meter: 453
PROBLEM ?
what is this i use offline set up 2 years ago till 2 weeks ago "
now "
Authentication stage error: Server reported error: No more upgrade logs. Please contact your reseller!
Old 12-27-2019, 11:13   #33 (permalink)
beo_tech's Avatar
Member: 222999
Thanks Meter: 75
same problem..
LIC: True
Old 12-28-2019, 13:50   #34 (permalink)
Member: 1517419
Thanks Meter: 7
Old 12-29-2019, 15:31   #35 (permalink)
Member: 1517419
Thanks Meter: 7
server on this time all ok
The Following User Says Thank You to rafiq_2009 For This Useful Post:
Old 01-02-2020, 18:32   #36 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 200
server down.............
Old 01-22-2020, 22:32   #37 (permalink)
Member: 2187588
Where is link plezzz
Old 01-31-2020, 21:20   #38 (permalink)
-=MR_Gsm=-'s Avatar
Member: 762055
Sonork: -=664053=-
Thanks Meter: 778
UFS_PANEL_2.3.0.9
BR,
-=MR_Gsm=-
The Following User Says Thank You to -=MR_Gsm=- For This Useful Post:
Old 02-22-2020, 08:25   #39 (permalink)
helpo's Avatar
Member: 2175357
Thanks Meter: 453
Guys is there trusted way to install it offline all pervious ways is not successful
Sent from my INE-LX1 using Tapatalk
Old 06-29-2020, 07:28   #40 (permalink)
Member: 1194110
Thanks Meter: 113
UFS Panel 2.3.0.9 Tested
http://www.mediafire.com/file/3lp4nm804mfqj0z/%255BGrahaFlasher.COM%255D_UFS_PANEL_2.3.0.9.rar/file
The Following User Says Thank You to [aNt] For This Useful Post:
Old 07-01-2020, 21:39   #41 (permalink)
Member: 1564630
Sonork: the blackchinese
Thanks Meter: 18
This one is working.After almost one year,my hwk box is working.
Old 07-02-2020, 17:36   #42 (permalink)
Dr_Wolodya's Avatar
Member: 75408
Thanks Meter: 1,190
But without "imei fix" button.
Old 07-04-2020, 12:24   #43 (permalink)
Member: 2124329
Thanks Meter: 44
tested its working again great job
Old 07-31-2020, 12:52   #44 (permalink)
Registered User
Member: 185010
Sonork: alias-albertino
Thanks Meter: 170
please someone should tell me is the server down ? I cant download the setup
everything about my box is ok
App: UFSx (HWK) Control Panel v 2.3.0.9 by SarasSoft
Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30
Box: 1 Location: 289 Serial: 98669
UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 98669
HID: E8C53E1F4160005B, HWK: A1.04-PRO1
LIC: True
BoxStat : Ok
LIC: True
BoxStat : Ok
All is Ok, not Need to Update Box or Support
Old 08-01-2020, 17:30   #45 (permalink)
Member: 237256
Thanks Meter: 91
[QUOTE=albert maren;14166986]please someone should tell me is the server down ? I cant download the setup
LIC: True
BoxStat : Ok
LIC: True
BoxStat : Ok
All is Ok, not Need to Update Box or Support[/QUO
Albert you are almost done. Open support panel and do CHECK AND NEXT INSTALL/AUTH
Your result should be:
Paths Updated
Software Authorised
Once you get the above result know that your license has been dropped in to your pc registry.
Next manually install software by unzipping(UFS3 PANEL 2.7.0.8 AND ALL SOFTWARE) into the path PROGRAME FILE/NOKIA/PHOENIX/PRODUCT and the second one PROGRAMME FILE/SARASOFT/UFS
Now run any software of your choice and it will connect and work.
The Following User Says Thank You to pastor good For This Useful Post:
Page generated in 0.19246 seconds with 8 queries
