06-29-2012, 03:15 | #1 (permalink) |
Insane Poster Join Date: Jun 2012 Location: Bankura,West Bengal
Member: 1772873 Status: Offline Thanks Meter: 9 | X1-01 Checksum mismatch Problem Using device: HTI, FW ver: 00.24, SN: xxxxxxxx Connection status: UHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12923(10-10-2011) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU: XGOLD 110 Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.24 EBL version : Default_RAM_Bootloader Set baud rate to: 921.60 Kbps Flash ID: 0020 8804 [ST 58LR128U,128 Mbits] Processing file: rm713_005.440 Downloading item CODE:hw_b1_rm713_r05.440.fls, num block: 3, size: 5.58 MB Erasing area 0x00000000-0x00005FFE ...OK Programming completed in 1.094 s Erasing area 0x00800000-0x00BEFFFE ...OK Programming completed in 2 min 6.141 s Erasing area 0x00C5D000-0x00DFB6FE ...OK Programming completed in 52.219 s Checksum mismatch: Phone calculated 0x48F6, software calculated 0xCD0A Processing file: rm713_005.44mg Downloading item CUST:hw_b1_rm713_005.44mg.fls, num block: 1, size: 5.01 MB Erasing area 0x00100000-0x0060257E ...OK Programming completed in 2 min 40.828 s Checksum mismatch: Phone calculated 0x30D2, software calculated 0xD828 Processing file: rm7130_nai05.44mg_nlt Downloading item CUST:hw_b1_rm7130_nai05.44mg_nlt.fls, num block: 1, size: 1015.45 KB Erasing area 0x00E60000-0x00F5D0BE ...OK Programming completed in 31.922 s Checksum mismatch: Phone calculated 0xA7E4, software calculated 0xBCDC Total time for flashing process(boot+erase+write) was 8 min 23.672 s Please help If Any solution? |
07-01-2012, 05:32 | #3 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | why you are sharing mxbox log in hwk section rehot cpu and flash again you problem will be solved |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
07-02-2012, 08:06 | #4 (permalink) | |
No Life Poster Join Date: Oct 2009 Location: srilanka Age: 39
Member: 1133072 Status: Offline Thanks Meter: 505 | Quote:
wrong selection. this is HWK selection. post right selection for get good help. B,R-chamisrilanka | |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
