07-21-2012, 00:14 | #1 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 223166 Status: Offline Thanks Meter: 14 | How to unlock MYX-2 - Connect LPT cable and usb to sagdd box - Opening the phone and remove keypad - Half assembly phone to connect battery. - Connect sag 3 in 1 cable to sagdd box with the phone, and this turn on green lights - Open SAGDD_9.6 - Select Unlock Device: Dongle - Set phone speed to 19200 - With direct unlock checked or unchecked click in Do the Job (unlock) Always get th same error: PROBLEM: Failed to read IMEI! If i click in Phone code read/deactivate i get this error: PROBLEM: Choose COM Port! |
07-21-2012, 06:56 | #2 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Europe
Member: 9544 Status: Offline Thanks Meter: 5,533 | @Fernyx - Phone speed AUTO; - for NCK reading you must connect TP adapter to cable and phone (or solder wires - TP picture is accesible on support area.). |
07-21-2012, 06:58 | #3 (permalink) |
No Life Poster Join Date: Jun 2002 Location: East Europe Age: 51
Member: 12837 Status: Offline Thanks Meter: 2,740 | There is wrong or missing connection between box and phone system connector. Don't forget that My X-2 unlock requires both (JTAG and data cable) connections. |
07-23-2012, 16:31 | #8 (permalink) | |
Member: 223166 Status: Offline Thanks Meter: 14 | Quote:
What i'm doing wrong?? https://dl.dropbox.com/u/25534020/IM...723_170307.jpg https://dl.dropbox.com/u/25534020/IM...723_170324.jpg https://dl.dropbox.com/u/25534020/IM...723_170249.jpg If i click in direct unlock still PROBLEM: Failed to read IMEI! If i click in Phone code read/deactivate i get this error: PROBLEM: Choose COM Port! With speed auto problem setting phone speed. I've tried with or without test point... Thanks | |
07-23-2012, 16:41 | #9 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @Fernyx Most sagem not turn on without LCD. put LCD on phone, plug cable it will show charging power on it. set jic on pcb by holding it by hand.phone should be on condition. unlock device should be dongle. press do job. if you did all correct its show you to restart phone remove connector jic replug. just reconnect phone in power on condition without JIC this time. and it will do direct unlock or code read any of you selected. Regards, Chevli |
07-23-2012, 22:11 | #10 (permalink) | |
Member: 12837 Status: Offline Thanks Meter: 2,740 | I think cable set are wrong ... in the pictures 'SCDR2 Sag MyX-X' label are shown The SagDD JTAG cable set are NOT compatible with competitors products Download SagDD data cable wiring diagram from support area and rearrange cable br Quote:
07-24-2012, 00:19 | #11 (permalink) | |
I never used before, i think this cable came to me with SAGDD pack with TP, or is a PolarBox cable because i don't have any other sagem tool. Can i use this cable?? Thanks | |
07-24-2012, 00:24 | #12 (permalink) | |
I'll try turn on with LCD, connect cable, remove LCD, put JIG and do the procedure... | |
07-24-2012, 05:52 | #13 (permalink) |
Member: 12837 Status: Offline Thanks Meter: 2,740 | |
07-24-2012, 15:27 | #14 (permalink) | |
Member: 223166 Status: Offline Thanks Meter: 14 | Quote: In the post came a photo but not say the difference neither pin must change... Thanks | |
07-24-2012, 17:46 | #15 (permalink) | |
Member: 12837 Status: Offline Thanks Meter: 2,740 | I'm sorry but referenced cable schematic is unknown for me ... and for wires rearranging SagDD cable schematic is enough br Quote:
