12-04-2007, 11:12 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Madrid, ES. Age: 41
Member: 51153 Status: Offline Sonork: 100.113241 Thanks Meter: 3,682 | my400v Hardware failure i use this: A- Cable Sagem MYC-2 B- SoftWare Sagem furious Calculator - Cracked- 1- Start Sagem furious Calculator. 2- Go to Setting shoose your Com Port ** COM1 or.......** and Thread Priority ** Normal **. 3- Go to Bootsrap and communication. 4- Let Answer Mode ** HEX ** 5- Power ON the phone and connect it 6- Press **Connect** Answer Ok 7- Fill in box **Field number** 268 and Press **Read** answer OK Field 268 (2 bytes): XXXX 8- show **Field data** XXXX 9- Change this value To 0000 10- Press **Write** Answer Ok 11- Power OF the phone 12- Hop its all Ok |
12-06-2007, 13:11 | #2 (permalink) |
Cheater -Don't Deal with him- Join Date: Aug 2005 Age: 57
Member: 169208 Status: Offline Thanks Meter: 1 | repair two minut my400v Hardware failure today repair two minut my400v Hardware failure solucion; 1 start sagem tools selektion baudrate 19200 2 start sagem dr14c 3 com1 4 selektion 5 edit eprom field 5 Field 268 (2 bytes): 0c00 6 repair field 268 ---- 0000 7 successfully 8 sagdd unlock procedura its ok thanks skenda from prishtina email [email protected] |
my400v hardware failure | ntek | SMTi | 20 | 06-02-2008 14:07 |
My400v Hardware Failure | ahmedksal | SMTi | 4 | 03-29-2008 16:53 |
***My400v Hardware Failure Repaired + Direct Unlock 1000%*** | Amir-SkillZ | SAGEM JTAG UNLOCKER | 1 | 03-22-2008 17:27 |
i have my400v hardware failure mobile blocked | saeed-gsm | SwS_SaG_BoX | 1 | 07-10-2007 09:38 |
My400v , hardware failure. | Raklm | ARM9 BASED M62 / M62+ | 3 | 01-04-2007 17:45 |
