Unloking with the Astro Ericsson Can some give me a step by step guide to unlocking a k700i, icant seem to get antwhere :confused: Thanks in advance Andre |
1.Just check where it's installed the 4 in 1 cables to check the port.Select the comport before start. 2.If the comport it's not there Scan for avaible ports. 3.Select now the comport. 4.Press connect 5.Press "Direct Unlock" 6.Unlocked in a few seconds PS:Astro team one of my *******r is complaining about when he calls someone the other guys heard him to high...Maybe this is a bug??It's a k300 where this was detected... |
@Luskao: This can be hardware or software faults, could you maybe post here the firmware version? Did this happen after unlocking/flashing with Astro Ericsson? |
After unlocking only..That's why I told him that I think it's hardware problem. Firm version was CID36 first version I'm not pretty sure about what phone version...:S BR |
Thanks for your help luskao. I'm trying to debrand a k300i and i'mm totally confused as to what file to use from the support site and where to place them within Astro Ericsson. Any help would be kindly appreciated. regards andre |
Andre, add me to icq, msn or sonork and I will help you with any problem you could have :) You only have to select main file where you see main and fs file that who shows the language extension in the second place. SFA file it's only necessary if for example you don't have any file with your language. Put that and it will have it. I reccommend to flash first Main and Fs files with complete phone thicked and then if necessary flash SFA file. If you need to convert the phone from CID29 to CID36 download EROM from support area and flash only main without complete phone. I suggest 460800 for speed until next version will be released in order to avoid errors. BR |
@Luskao: There is some baudrate communication conflicts for some marita full and marita compact phones, this conflict will be solved in next verison hopefully. |
That's the word...Marita :) yes, the soft said set marita speed at 460800 Hoping the best :) BR |
