Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
11-04-2016, 19:45 | #1 (permalink) |
Junior Member Join Date: Aug 2008 Location: Virtual Machine
Member: 830863 Status: Offline Thanks Meter: 3 | Alcatel 9001D , 9001X stock ROM |
The Following 3 Users Say Thank You to Albastrel For This Useful Post: |
11-05-2016, 02:17 | #2 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,786 | Quote:
b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following User Says Thank You to Brka For This Useful Post: |
03-01-2017, 08:00 | #4 (permalink) |
No Life Poster Join Date: Aug 2015 Location: Gujranwala Age: 25
Member: 2451476 Status: Offline Sonork: 100.1669164 Thanks Meter: 345 | Alcatel tcl 9001d dead boot repair help `````ALCATEL TCL 9001D DEAD BOOT REPAIR HELP````` PLEASE ANY SOLUTION! ONLY WHITE LIGHT BLINKING |
03-01-2017, 23:50 | #5 (permalink) | |
If you have, or can find another battery - try with it. Re-check again with charged / changed battery, what is the state of the phone. Does it appear as Qualcomm 9008 or 9006 port ? b.r. Alex
06-17-2017, 14:49 | #6 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: Professional Mobile Unlocker Age: 41
Member: 617174 Status: Offline Sonork: 100.1622609 Thanks Meter: 579 | Quote:
Qualcomm 9008...................................... | |
The Following User Says Thank You to vodafoneserver For This Useful Post: |
06-17-2017, 15:18 | #7 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,786 | Serbian Retail stock ROM, Use qfil flasher to flash it. Download link : ot-9001D-2xALRS1_D37_Original_Stock_ROM_by_bRkA archive pass: forum.gsmhosting.com p.s. Copy-Pasters MUST and WILL die. B.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 07-17-2018 at 22:37. Reason: fixed link |
The Following 5 Users Say Thank You to Brka For This Useful Post: |
07-01-2017, 00:10 | #9 (permalink) | |
Ireland Original STOCK Retail ROM, no branding, QFIL flashable format. QFIL / QPST Flasher - HERE Flashing instructions - HERE archive pass (if needed) : forum.gsmhosting.com b.r. Alex
07-02-2017, 00:46 | #10 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2212629 Status: Offline Thanks Meter: 0 | Brka: In ROM for OT-9001X that you linked above there is something strange to me. There is no "prog_emmc_firehose_8909 . mbn" in archive, but two another files of .bin extension ("prog_emmc_firehose_8909 . bin" and "prog_emmc_firehose_8909_2 . bin"). How in this case use QFIL and what select as programmer? Or maybe this ROM is broken? Thanks. PS. I used spaces near dots because of "no link" protection for young forum users. |
07-02-2017, 02:08 | #11 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,786 | Just rename to .mbn , try first loader first, if wont boot, use second one. I forgot to rename to .mbn b.r. Alex
07-02-2017, 05:11 | #12 (permalink) |
Junior Member Join Date: Feb 2016
Member: 2529558 Status: Offline Thanks Meter: 0 | i can not go to download mode i tried holding both volume keys insert cable, up volume insert cable, then down volume but none works. the phone keeps going to recovery mode. i have wipe data/factory reset like several times in the recovery mode but it keeps going to recovery mode when on. please i really need help in this. |
07-02-2017, 09:11 | #13 (permalink) |
Member: 2212629 Status: Offline Thanks Meter: 0 | Go to recovery mode - than chose power off. When power is off ... hold vol up and vol down together and plug the cable. In result you will get alcatel logo on the screen for the moment, but after that screen will go black, but device will be accessible from PC. BTW. I have another problem - only windows that I have is XP on virtualbox - and problem is that QFIL doesn't see any serial Port - when plugging phone in I hear the sound (bam bim) and I see HID device in device manager, but no any serial port. |
07-02-2017, 10:59 | #14 (permalink) |
Member: 2212629 Status: Offline Thanks Meter: 0 | I don't see edit option, so I have to add another post. Actually I think that we have same problem, me and kokoo1993. For me Phone is visible under Windows as Android Device - not Qualcomm_something_blablabla that would be accessible from QFIL. This device seems to be not compatybile with qualcom driver that I installed. Anyway, in my case it may be problem of using VirtualBOX instead of native windows. But on another hand, I saw many comments, that people doesn't have any problems with using QPST on Virtualbox. |
07-02-2017, 21:07 | #15 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,786 | Download correct drivers: USB_driver_Alcatel-QCOM Download, unpack, start "DriverInstaller.exe", do Uninstall first, then Install. DOwnload mode is , on powered off phone, holding both volume keys and insert usb cable, tested recently. b.r. Alex
