Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Alcatel > Alcatel TCL Phones and New Models
Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections.
Old 12-25-2013, 14:12   #1 (permalink)
GsmExpertz.Clt's Avatar
Member: 74036
Sonork: 100.1601291
Thanks Meter: 42
how to enter unlock code alcatel 5020t
sir
cant option to enter unlock code, any solution??
best regards
The Following User Says Thank You to GsmExpertz.Clt For This Useful Post:
Old 12-26-2013, 05:22   #2 (permalink)
Member: 74036
Sonork: 100.1601291
Thanks Meter: 42
i have code but can't enter option
thanks
Old 12-26-2013, 10:51   #3 (permalink)
Member: 2052204
Thanks Meter: 2
I have same issue with my Alcatel 7024w from T Mobile USA - bought unlock code,but have no option to put the code in
Old 12-27-2013, 11:44   #4 (permalink)
Member: 76522
Thanks Meter: 30
because counter was blocked. u need to full wipe phone and than u will have posibiliuty to enter code.
Old 12-27-2013, 13:11   #5 (permalink)
Member: 2052204
Thanks Meter: 2
CLIFFORD25502 :but it does not help me-I did full wipe from recovery and from menu too so many times without any progress
in engineer mode is simme lock option grayed ...Think need reflash it,but booloader is locked and there is no firmware/update/ to download too
Old 12-27-2013, 13:25   #6 (permalink)
Member: 76522
Thanks Meter: 30
Where u read that u need do wipe from recovery? u need to wipe it via adb ( adb wipe all ), but seems needed root for it.
Old 12-27-2013, 18:32   #7 (permalink)
Member: 2052204
Thanks Meter: 2
Will try when I came back to home,thank You for reply.
Old 12-27-2013, 20:16   #8 (permalink)
Member: 2052204
Thanks Meter: 2
Movileuropa You think 7024w Fierce or 5020t?As I understand,we both have unlock codes already,but no option to it in...and we need only reset unlock counter /I hope so/
Old 12-29-2013, 17:00   #9 (permalink)
Member: 534777
Thanks Meter: 214
Can you please assist me as to where you bought the unlock code for your alcatel 7024w???
have one and need a code service to buy the code.
thanx and best wishes
Old 12-29-2013, 22:21   #10 (permalink)
Member: 2052204
Thanks Meter: 2
Have problem to switch Fierce in fastboot mode...enabled developer mode,usb debugging selected,power+volume down start,but it doesnot stop on android(?!?)and adb commands dont see Fierce on cable...
Old 01-25-2014, 01:23   #11 (permalink)
Member: 2113822
alcate onetouch evolve 5020T
Here is what you need to do. You need a differnt sim that don't go to the phone put it in the phone after taking out the original one put 2 sim in and wait to a phone key pad shows in put 23385694 and it should unlock your phone
Old 01-25-2014, 01:36   #12 (permalink)
Haicha's Avatar
Member: 330579
Thanks Meter: 67,515
Friend! With counter blocked !!!?
Old 06-16-2014, 17:35   #13 (permalink)
Member: 1927065
U must format it in recovery mode(Voldown+PowerON, navigate with volume buttons to clear eMMC, and then press the middle key on the touch).
It will ask for the nck after U did it.
B.r.
Ceru
Old 06-17-2014, 08:58   #14 (permalink)
Registered User
Member: 632643
Thanks Meter: 74
B.r.
Ceru
as the thread starter said many times he already did reset on recovery mode and NO LUCK!!! read posts before reply!!!
Old 06-17-2014, 13:28   #15 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
Originally Posted by GsmExpertz.Clt View Post
sir
best regards
1 - Switch ON your Alcatel with a NOT ACCEPTED SIM Card,
2 - When the message "Enter Network Key" appears, enter the Unlock Code.
*NOT ACCEPTED : means, to use a sim card from a network other than the network your Alcatel is locked to.
OR
1 - Switch ON your Alcatel WITHOUT SIM Card,
2 - Then compose : *#0000*CODE#,
3 - To finish compose : *#0001*CODE#.
Page generated in 0.17600 seconds with 9 queries
