Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
12-27-2013, 11:48 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Age: 47
Member: 76522 Status: Offline Thanks Meter: 30 | Need tp for alcatel ot-5035x Thx in adwance! |
03-12-2014, 15:49 | #2 (permalink) |
Member: 76522 Status: Offline Thanks Meter: 30 | Finaly i find boot tp. But now sp flash tool give me always error 3002 when i try to flash my phone. any ideas how to bypass this error? chip seems be ok. i format it and also test it. also i use differnt pc and spflashtool versions. |
04-04-2014, 07:32 | #3 (permalink) |
Freak Poster Join Date: Feb 2004 Location: Romania Age: 48
Member: 52722 Status: Offline Thanks Meter: 18 | I have one pcs same alcatel.... dead... But when I conected at pc... in device magager show me MTK USB.... From other situation that SPTOOL to make good work pc must recognized your phone , somethig like that: MTK DA VCOM .... must install special driver like MT6577 vcom where MTxxxx is procesor from device (in this case , I don kwnow exacly because i'm home) Do you have firmware for this phone ??? or TP ? Br Mihnea |
04-07-2014, 07:49 | #4 (permalink) |
Member: 76522 Status: Offline Thanks Meter: 30 | You dont need tp/ Just firest flash preloader and u see MTK DA VCOM port. After that u can flash firmware. Now u have just empty preloader. Contact me with skype (clifford25501) if u need firmware. |
09-13-2014, 18:36 | #6 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | newer SPFlashTools support "empty" aka formatted phones. it just asks for different driver. install it, and flash ROM_0, readed from working, same model phone, and you will have fully working phone. for details on how-to, search my posts, I wrote detailed instructions. b.r. Alex |
09-16-2014, 19:54 | #8 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
totally empty phone must be recognized via USB without any tp, try also holding volume up, or volume down, then plug it to usb, if still nothing, battery ... if after charging battery, still not recognized, it bricked, but not via software, probably hardware error. (dead eMMC, dead cpu, etc.) b.r. Alex | |
09-18-2014, 12:10 | #9 (permalink) |
Junior Member Join Date: Sep 2014
Member: 2256194 Status: Offline Thanks Meter: 0 | Thanks for the reply phone got brick my fault I wrote preloader for ot 5035d . And now it is not recognized by pc I've read that only by test point one can work something out . And I want to do this because then I can try several versions of this software . is more of a stubbornness to bring it to life is my mistakes I was rushed thanks in advance Mihai |
09-18-2014, 17:34 | #10 (permalink) | |
try volume up and insert cable, or volume down + insert cable or both volume keys + insert cable or all above + pressing power-on key. I killed one 6012x, intentionally, but was able to boot it. check it out, and write results. b.r. Alex | |
The Following User Says Thank You to Brka For This Useful Post: |
09-20-2014, 18:31 | #11 (permalink) |
Member: 2256194 Status: Offline Thanks Meter: 0 | hello Thanks a lot The combination of + , -, power button was the winner. The phone was recognized by the PC. But surprise , went to write only preloader . It blocks you want to write in flash . To check the memory I saw that I write ERROR : NAND Flash WAS not detected ! I think the problem is in formatting NAND . What do you think about this. Sorry I answer difficult but I still struggled to do something. Me and my stubbornness . Thanks for the help you've given me so far . Mihai |
09-20-2014, 18:43 | #12 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | okay, so it's not dead. next step, you need working phone and scatter file, to read full ROM_0 backup. instructions HERE I recommend you to first root that working phone, and put CWM recovery in it, because, after writing that rom into dead phone, it will probably be in boot-loop state (because of not existing data + cache partitions, which can be formatted under CWM recovery) so ... the process would look like : - master reset that working phone, - root + cwm into working phone - SPFLashTools, load scatter file, MEMORY read, up to cache partition address - it will make ROM_0 file, size around ~900Mb up to 1.2-1.3Gb - SPFlashtools, again to write that file into dead one, option WRITE MEMORY - after writing phone should power on - if after power on have have boot-loop, go to cwm, and format data+cache partitions after all of that, it should power on normally and have same software as readed phone, original imei and all working. use this spflashtools : SP_Flash_Tool_v3.1224.01 if you stuck somewhere ... I can help via teamViewer, just add me on Skype. pm for details. b.r. Alex |
09-20-2014, 19:56 | #13 (permalink) |
Member: 2256194 Status: Offline Thanks Meter: 0 | ok Alex Try it now but it takes some time to process information if I have some questions I have to tell you, Thank you once again that you take the time to answer me and have patience with my stubbornness . Mihai |
09-22-2014, 17:35 | #15 (permalink) | |
that's why you need full backup, which will bring it back to life. and for that, you need one working phone, to read ROM_0 backup. b.r. Alex | |
