Need vfd300 firmware Pls give me a vfd300 stock rom ,i flashed and now it 's get brom error 4032. pls gove me a V300-2AVDNZ2 ROM THANK U SO MUCH |
Download the official Vodafone Smart Mini 7 VFD300 Stock Firmware (Flash File) for your Vodafone Device. |
Hi, You can try with the VODAFONE VFD300 SMART MINI just untick preloader file option, when you perform flash with SP Tools. Firmware credit needrom.com |
Thnk u so much ur big help .but problem same. Ithink i should repair preloader or find same pid rom .thx again *** EDIT: finally success. my phone alive again.thx all of u |
dear How did you do ? Same issue error 4032 with all the firmware... VFD300 |
same problem here ................................. |
2 Attachment(s) Firmware links : MT6580__VODAFONE__VFD_300__Smart_mini7__VFD300__al ps-mp-m0.mp1-V2.34_jhz6580.weg.vf.m_P38__Android_6.0 PID: V300-2AVDZA1 (Vodafone South Africa); BOX BACKUP ; Reported as tested and working MT6580__VODAFONE__VFD_300__Smart_mini7__VFD300__al ps-mp-m0.mp1-V2.34_jhz6580.weg.vf.m_P115__Android_6.0 PID: V300-2AVDZA1 - (Vodafone South Africa) ; BOX BACKUP ; pass: humapkehaikon *** EDIT: One more ROM for test - download : MT6580_S00_EMMC_MRA58K__6.0_VFD 300_Vodafone PID: V300-2BVDAU1 (Vodafone AUstralia) *** EDIT2: Vodafone UK rom : V300-2AVDGB2 , alps-mp-m0.mp1-V2.34_jhz6580.weg.vf.m_P23 *** EDIT3: Vodafone Australia rom : V300-2BVDAU1 , alps-mp-m0.mp1-V2.34_jhz6580.weg.vf.m_P68 thanks to gile@gile for this last australian rom (box backup, scatter) NOTE: First two downloads are box backup, single file, which can be unpacked using 7zip archiver. After unpacking, use attached Scatter file, put in unpacked folder. Load scatter in SPFlashTools, go to tab FORMAT, do FORMAT ALL EXCEPT BOOTLOADER, and do format. After finished, go to download tab and flash the phone normally, it will restore all sensitive partitions. If your device doesn't power on, use flash file from 3rd link, which have preloader inside, then if bootloop, use above procedure. try and post results. b.r. Alex |
Hello, i got the same problem, tested, all the roms are posted in this forum. Got stock on a circle load. I got VFD300 V300-2AVDPT1 Vodafone Portugal. Have anyone faced the same issue? |
After like 50 different tries and modes, i finally put this back working. wasted 2 days on this. I did reflashed the last firmware P115 and it finnaly worked. Its came with pattern, removed pattern with box, on boot it stuck, holded power on button till reset itself and then next boot loaded correctly, then removed google, and reset the setting from menu, next boot, phone stuck again, i did repeated the power button force restart, and spinng circle finnaly passed to menu! so mutch time wasted. |
vfd 300 stuck on round circle vfd 300 stuck on round circle try all file not done any salution:confused: |
after flashing with good userdata/cache and making reset from phone menu, all works normal. So, if phone power on normal, flash whole flash without preloader, and wait unti phone boot up. All answers are in posts #8 and #10. Read carefully and try to do as described. b.r. Alex |
boot loop solved after many flash(first file used after extract with 7zip and flashed with spflash) thanks |
VFD300 Flash successful I used the first file and noticed there was no scatter file so I used the scatter from a previous file I downloaded,didn't format and didn't flash preloader,otp and pgpt,all working fine.Thank you BR 4mula:D |
need the firmware vodafone VFD300 V300-2AVDPT1 Vodafone Portugal plz thanks its urgent my phone dead |
