Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
01-26-2018, 06:11 | #1 (permalink) |
Freak Poster Join Date: Feb 2005 Location: srilanka Age: 40
Member: 115858 Status: Offline Sonork: 100.1670724 Thanks Meter: 35 | Need vfd300 firmware pls gove me a V300-2AVDNZ2 ROM THANK U SO MUCH |
01-26-2018, 06:34 | #2 (permalink) |
Junior Member Join Date: Jan 2018 Location: uk
Member: 2804069 Status: Offline Thanks Meter: 1 | Download the official Vodafone Smart Mini 7 VFD300 Stock Firmware (Flash File) for your Vodafone Device. Last edited by Brka; 03-17-2019 at 23:08. Reason: fixed link |
The Following User Says Thank You to phongnet For This Useful Post: |
01-26-2018, 17:54 | #4 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Hi, You can try with the VODAFONE VFD300 SMART MINI just untick preloader file option, when you perform flash with SP Tools. Firmware credit needrom.com
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
01-27-2018, 13:59 | #5 (permalink) |
Member: 115858 Status: Offline Sonork: 100.1670724 Thanks Meter: 35 | Thnk u so much ur big help .but problem same. Ithink i should repair preloader or find same pid rom .thx again *** EDIT: finally success. my phone alive again.thx all of u Last edited by Brka; 03-17-2019 at 23:10. Reason: merged |
09-17-2018, 22:19 | #8 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Firmware links : MT6580__VODAFONE__VFD_300__Smart_mini7__VFD300__al ps-mp-m0.mp1-V2.34_jhz6580.weg.vf.m_P38__Android_6.0 PID: V300-2AVDZA1 (Vodafone South Africa); BOX BACKUP ; Reported as tested and working MT6580__VODAFONE__VFD_300__Smart_mini7__VFD300__al ps-mp-m0.mp1-V2.34_jhz6580.weg.vf.m_P115__Android_6.0 PID: V300-2AVDZA1 - (Vodafone South Africa) ; BOX BACKUP ; pass: humapkehaikon *** EDIT: One more ROM for test - download : MT6580_S00_EMMC_MRA58K__6.0_VFD 300_Vodafone PID: V300-2BVDAU1 (Vodafone AUstralia) *** EDIT2: Vodafone UK rom : V300-2AVDGB2 , alps-mp-m0.mp1-V2.34_jhz6580.weg.vf.m_P23 *** EDIT3: Vodafone Australia rom : V300-2BVDAU1 , alps-mp-m0.mp1-V2.34_jhz6580.weg.vf.m_P68 thanks to gile@gile for this last australian rom (box backup, scatter) NOTE: First two downloads are box backup, single file, which can be unpacked using 7zip archiver. After unpacking, use attached Scatter file, put in unpacked folder. Load scatter in SPFlashTools, go to tab FORMAT, do FORMAT ALL EXCEPT BOOTLOADER, and do format. After finished, go to download tab and flash the phone normally, it will restore all sensitive partitions. If your device doesn't power on, use flash file from 3rd link, which have preloader inside, then if bootloop, use above procedure. try and post results. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 08-17-2021 at 22:26. Reason: added link |
The Following 7 Users Say Thank You to Brka For This Useful Post: |
09-26-2018, 00:01 | #9 (permalink) |
Insane Poster Join Date: Jan 2014 Location: pt
Member: 2103265 Status: Offline Thanks Meter: 59 | Hello, i got the same problem, tested, all the roms are posted in this forum. Got stock on a circle load. I got VFD300 V300-2AVDPT1 Vodafone Portugal. Have anyone faced the same issue? |
09-26-2018, 01:13 | #10 (permalink) |
Member: 2103265 Status: Offline Thanks Meter: 59 | After like 50 different tries and modes, i finally put this back working. wasted 2 days on this. I did reflashed the last firmware P115 and it finnaly worked. Its came with pattern, removed pattern with box, on boot it stuck, holded power on button till reset itself and then next boot loaded correctly, then removed google, and reset the setting from menu, next boot, phone stuck again, i did repeated the power button force restart, and spinng circle finnaly passed to menu! so mutch time wasted. Last edited by Brka; 03-17-2019 at 23:12. Reason: removed quoting |
The Following User Says Thank You to d1m0n69 For This Useful Post: |
03-17-2019, 22:07 | #12 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
after flashing with good userdata/cache and making reset from phone menu, all works normal. So, if phone power on normal, flash whole flash without preloader, and wait unti phone boot up. All answers are in posts #8 and #10. Read carefully and try to do as described. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 03-17-2019 at 23:14. Reason: info added | |
12-12-2019, 19:56 | #13 (permalink) | |
Freak Poster Join Date: Jul 2005 Location: 5180 Age: 41
Member: 161183 Status: Offline Thanks Meter: 95 | Quote:
boot loop solved after many flash(first file used after extract with 7zip and flashed with spflash) thanks | |
The Following User Says Thank You to KHALED_MB008 For This Useful Post: |
03-09-2020, 07:57 | #14 (permalink) |
Freak Poster Join Date: Jan 2014 Location: Zimbabwe
Member: 2100642 Status: Offline Thanks Meter: 46 | VFD300 Flash successful I used the first file and noticed there was no scatter file so I used the scatter from a previous file I downloaded,didn't format and didn't flash preloader,otp and pgpt,all working fine.Thank you BR 4mula |
The Following User Says Thank You to 4mula For This Useful Post: |
