Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Hardware Repair
Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing.
Old 12-17-2006, 10:08   #1 (permalink)
Member: 366372
Thanks Meter: 7
c168 blanck display
how to repair motorola c168 blanck display only blue light display
The Following 3 Users Say Thank You to 197700 For This Useful Post:
Old 12-17-2006, 10:31   #2 (permalink)
Member: 218793
Thanks Meter: 29
try full flash if not don chack hardware lcd and lcd driver
The Following User Says Thank You to syedqurat For This Useful Post:
Old 12-17-2006, 11:05   #3 (permalink)
Member: 366372
Thanks Meter: 7
full flash is ok but same pero. can i see lcd driver
The Following User Says Thank You to 197700 For This Useful Post:
Old 06-02-2007, 09:36   #4 (permalink)
Member: 450906
Thanks Meter: 6
hello brothers i have c168 with blue lcd can any body help ........................
The Following 2 Users Say Thank You to cell2cellphone For This Useful Post:
Old 06-02-2007, 09:38   #5 (permalink)
piyush.kothiya's Avatar
Member: 515506
Thanks Meter: 28
168 blank lcd
Dear Friend
please try to flash with Infinity software, you will get 100 % result, i also tried that,
Thanks
Piyush
The Following 2 Users Say Thank You to piyush.kothiya For This Useful Post:
Old 06-03-2007, 04:42   #6 (permalink)
yashtel's Avatar
Member: 170589
Thanks Meter: 1,848
do the set respond on incoming or outgoing call if yes than check lcd and its connector... if not than full flash it
The Following User Says Thank You to yashtel For This Useful Post:
Old 06-04-2007, 18:13   #7 (permalink)
Member: 214035
Thanks Meter: 3
c168 blank display
SIR ,,,
CAN U HELP ME ABOUT C 168 BLANK DISPLAY???
SIR, PLS SEND ME DIAGRAM OF C168, AND HIGHLIGHT DRIER OF LCD....
SORRY FOR BAD ENG
The Following 2 Users Say Thank You to tawdesanket For This Useful Post:
Old 06-05-2007, 10:27   #8 (permalink)
Sullykaka's Avatar
Member: 363434
Thanks Meter: 4
change lcd if same problem
The Following User Says Thank You to Sullykaka For This Useful Post:
Old 06-12-2007, 17:32   #9 (permalink)
Member: 445245
Thanks Meter: 2
Hi
My unit responds to incoming and outgoing but the display is only white screen. I tried to remove LCD connector and put it back and the full display showed up but when I put the phone down its back to white screen. If I hold the upper portion of the phone where the LCD connector -the display will show up. What do you think will I do to keep the connector from loosing up.
Thanks
The Following 2 Users Say Thank You to azllamoso For This Useful Post:
Old 06-13-2007, 05:32   #10 (permalink)
kanwal's Avatar
Member: 496736
Thanks Meter: 17
how to flash it smart moto not support it
Old 06-13-2007, 21:08   #11 (permalink)
5mobile's Avatar
Member: 70278
Thanks Meter: 19
try this pic ,l hope will help u all ,this solution l try before ,but not 100% ,post reply
The Following 3 Users Say Thank You to 5mobile For This Useful Post:
Old 08-09-2007, 13:27   #12 (permalink)
Member: 469612
Thanks Meter: 6
thanks
your solution worked for me many thanks........
Old 08-24-2007, 16:17   #13 (permalink)
Member: 215651
Thanks Meter: 7
hai brothers c168 black display help me;;;;;;;;;;;;;;
Old 11-05-2007, 12:23   #14 (permalink)
Registered User
acelai00's Avatar
Member: 255011
Thanks Meter: 56
bro,you file can download but cant open the file in my computer....can post again?thx,,,,,,,
Old 01-21-2008, 20:01   #15 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
if continuty of these points are ok than also make jumper or not?
..::HUM::..
The Following User Says Thank You to HUM For This Useful Post:
C168 blue display k_abhi Motorola Hardware Repair 7 12-29-2011 12:30
motorola c168 blue display solution pls.............................................. manrew Motorola Hardware Repair 18 03-08-2010 07:52
2600 blanck display mestine Nokia Hardware & Hardware Repair 1 06-15-2008 09:58
c168 only display lights is not working ??? makkah mobile Motorola Hardware Repair 1 11-06-2007 04:25
X820 Blanck Display neo_49 UST Pro II 0 07-23-2007 16:21
Page generated in 0.26085 seconds with 10 queries
