Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
09-24-2007, 11:22 | #3 (permalink) |
Junior Member Join Date: Sep 2007
Member: 592524 Status: Offline Thanks Meter: 0 | Battery may be defective or may not be a Motorola original battery. After market battery (non- Motorola battery) was inserted, the battery does not have Motorola communication technology. |
09-30-2007, 22:00 | #7 (permalink) |
Junior Member Join Date: Feb 2005 Age: 45
Member: 119900 Status: Offline Thanks Meter: 0 | get it the following are responsible for motorola invalid battery---1- in the case of v3 check the resistor in the opposite direction with battery connector or---2-if u course charge the battery(direct charging) |
01-14-2008, 19:43 | #10 (permalink) |
Freak Poster Join Date: Apr 2007 Location: UIO - EC Age: 37
Member: 483230 Status: Offline Thanks Meter: 25 | Maybe... U have to check out the connections beetwen battery pads and power unit... Any element or track could be responsible... I Had that problem with V3i |
01-21-2008, 06:59 | #11 (permalink) |
Junior Member Join Date: Dec 2007 Location: I N D I A
Member: 649485 Status: Offline Thanks Meter: 1 | L-7 & L-6 invelid battary solution in motorola L-7 when insert batt. display show in velid batt. his solution is under . rebouling U-900, otherwise change. In L-6 rebouling U-900 otherwise change. please reply via email ( [email protected]) mihirgsm |
07-29-2008, 14:57 | #14 (permalink) |
Freak Poster Join Date: Jul 2005 Location: india Age: 44
Member: 162478 Status: Offline Thanks Meter: 13 | dearsssssss dear any one , boost the battery . i think u r problem is battery complaind (dont boost motrolo battry) pleas chang the battry & chek the set . thanku |
The Following User Says Thank You to nijascm For This Useful Post: |
L7 invalid battery | hasanphone | Motorola Hardware Repair | 15 | 05-30-2010 18:21 |
l7 invalid battery please help me | prakash40 | Motorola Hardware Repair | 8 | 02-06-2010 12:22 |
L7 invalid battery pls help | biniesh_08 | Motorola Hardware Repair | 8 | 08-27-2009 07:32 |
L7 Invalid Battery After Unluck Please Help | aang | Motorola Hardware Repair | 2 | 10-06-2006 09:41 |
L7 Invalid Battery | street | Smart-Clip | 4 | 05-05-2006 13:45 |
