Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
01-04-2010, 08:07 | #2 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Dominica, West Indies Age: 63
Member: 88701 Status: Offline Thanks Meter: 381 | Hi.... Disconnect speaker/switch flex and check again . :smokin |
The Following User Says Thank You to Orange_Dominica For This Useful Post: |
01-04-2010, 20:32 | #4 (permalink) |
Member: 88701 Status: Offline Thanks Meter: 381 | Hi... You need to troubleshoot the ( speaker/ switch )flex connector on the main LCD. Or....if the buttons are not important....disconnect the flex completely...and run 2 wires from the flex connector to the speaker. Make sure the (speaker/switch flex).. that you tested with is good. :smokin |
01-05-2010, 14:08 | #6 (permalink) |
Member: 88701 Status: Offline Thanks Meter: 381 | Hi... The speaker/switch flex contains no active componants ...its just connections from the flex connector to the switches. You need to troubleshoot and find out which line is shorted. Remember to look not only to the speaker/switch flex ...but the main flex connector too. If its not possible to fix.... then 2 options... 1. Disconnect the speaker/switch flex ...and solder 2 wires to the speaker from the speaker/switch flex. 2. Replace the LCD. (keyboard Flex connector) ------> (speaker/switch flex)---->to switches and speaker :smokin |
01-06-2010, 07:48 | #7 (permalink) |
No Life Poster Join Date: Dec 2007 Location: pakistan
Member: 652132 Status: Offline Thanks Meter: 146 | thanks brother , thanks for your opinion , actually the LED on the speaker/volume button strips , were water demaged , first i disconnect it and checked , it worked, then i repalced it , now its working , thanks brother |
V3i Keypad not working after new speaker flex | tyraen | Motorola Hardware Repair | 7 | 04-17-2009 09:40 |
V3i Keypade not worke | sekar_k | Motorola P2k | 1 | 08-31-2008 20:37 |
v3i....keypad..not working | raj1980 | Motorola Hardware Repair | 1 | 08-25-2008 17:36 |
v3i....keypad..not working | raj1980 | Motorola Hardware Repair | 7 | 06-20-2007 11:30 |
V3i Keypad Not working | rakishi | Motorola P2k | 0 | 06-01-2006 00:07 |
