Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
05-20-2008, 16:57 | #1 (permalink) |
Junior Member Join Date: May 2006
Member: 271140 Status: Offline Thanks Meter: 0 | Motorola V3i - earpiece not working It was dusty inside, so i cleaned it with air. I disconnected the ZIF sockets to remove the lcd assembly to replace the inner cover. Everything was successfully done. I replaced the lcd assembly into the housing. When I turn the phone it, the earpiece(the part you put up to your ear) no longer produces any sound. I have tried to increase the volume and still nothing. Only the speakerphone works. I have seen some other posts about bypassing the earpiece ribbon or replacing the flex ribbon. None of these ribbons seem to be physically damaged. I cleaned the flex ribbon contacts. Anyone have nay suggestion as to what I should do, or more importantly, what is underneath the black tape covering up the earpiece ribbon as it goes into the lcd assembly. Here are some pictures of the device. The device itself The flex ribbon and the zif connector The earpiece, its ribbon, and the bypass point: |
06-17-2008, 00:38 | #3 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: JAMAICA Age: 46
Member: 220143 Status: Offline Thanks Meter: 108 | Quote:
Thanks | |
06-18-2008, 06:43 | #4 (permalink) |
Junior Member Join Date: Apr 2008 Location: TANZANIA
Member: 759348 Status: Offline Sonork: Kassim ( Small Phone ) Thanks Meter: 9 | try to change the flex and ribbon again because, the flex and ribbon you are not good enough,do it your phone speaker will work fine in addition change audio ic |
motorola v3i earpiece problem | scion | Motorola Hardware Repair | 5 | 11-12-2009 06:18 |
10000000% working solution for k850 earpiece not working | dreameye | Sony Ericsson | 4 | 06-10-2009 10:25 |
c200 mic & earpiece not working | gbada | Motorola ODM | 3 | 06-08-2006 16:43 |
7260 earpiece not working | meneleo | Nokia Hardware & Hardware Repair | 4 | 02-26-2006 11:55 |
samsung x450 mic and earpiece not working | gbada | Samsung Hardware Repair | 1 | 09-18-2005 02:28 |
