Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
12-22-2010, 09:37 | #1906 (permalink) |
Freak Poster Join Date: Apr 2010 Location: Nepal
Member: 1294102 Status: Offline Sonork: 100.1655641 Thanks Meter: 79 | |
12-31-2010, 06:15 | #1909 (permalink) |
Junior Member Join Date: Dec 2010 Location: United States of America
Member: 1465421 Status: Offline Thanks Meter: 0 | I have a motorola droid that has been drowned. It is now turning on but the lcd is not working. I have read that they go bad first. But what do I need to do with RSD lite to revive it? I have RSD Lite 4.9, have not downloaded a SBF file for I do not know which file to get. |
01-18-2011, 19:43 | #1913 (permalink) |
Junior Member Join Date: Jan 2011
Member: 1496473 Status: Offline Thanks Meter: 0 | Motorola V220 Hi, I am having a problem texting. The keyboard is not working for letters in texts. It is working fine for phone calls and when switched to numbers, will type them in text. However, when I try to use it to type letters, the cursor stops, the screen freezes and then it switches itself off after 5 mins or so. No other key or the on/off switches work after you type in one letter. Any idea? Help. Thanks |
01-18-2011, 21:23 | #1914 (permalink) | |
Member: 1294102 Status: Offline Sonork: 100.1655641 Thanks Meter: 79 | Bro here are some codes for motorola.......!!!it may help u.......check it out!!! Quote:
IT WORKS BUT USE AT UR OWN RISK... motorola w220 display problem *#**367628#+send key master reset *#**778337#+send key E2p reset O2x1 reset password *#9999# Hang talk and power button together [??]secret motorola mpx200 codes engineering menu, test mode, logs, etc. Enter in the top secret 'Engineering Mode' on your MPx200 entering: *#**364# on your keypad then press the Green Button other interesting codes are: * # * * 3 7 2 # FQC (test mode) * # * * 3 6 4 # Engineering menu * # * * 2 6 6 * 0 # Set as data COM port * # * * 2 6 6 * 1 # Set as log COM port * # * * 7 9 7 # Time to failure timer & Power down code * # * * 2 2 6 3 * 0 # Set to default Band * # * * 2 2 6 3 * 1 # Disable GSM Band * # * * 2 2 6 3 * 2 # Disable DCS Band * # * * 2 2 6 3 * 3 # Disable EGSM and DCS Band * # * * 2 2 6 3 * 4 # Disable PCS Band * # 9 9 9 # which displays the command log * # * * 8 3 7 # Version info (some roms doesnt have implemented) Remember guys play at your own risk L6 i-mode Codes -------------------------------------------------------------------------------- This Mitsibushi codes work with L6 i-mode hold * 65512890 for reset hold * 5806 sw version hold * 487989 NS lock menu hold * 482896 CP hold * 574243 NS hold * 967678 SP hold * 362628 IMSI hold * 787090 Lock net level hold * 787292 Lock net level TSM30 FULLRESET CODE ##*#9374 and press ok , b ::Service Codes:: ##**9987 Motorola c350 english languge menu setting 1 1 5 2 6 (T190, T191, T205) master code - 19980722 - 20010903 ********** P2K test menu: *#06#, menu, menu, 048263* Test comands: 32*116*1*0*0 - read phone code 32*118*1*0*0 - read security code 18*0 - factory reset, phone code off 18*1 - master reset 54*18*1 - full phone reset 10*0*6 - select 900/1800 32*279*1*0*8 - model 32*383*1*0*0 - flex version Hard reset MPX200, MPX220 - blue button + power on 1) Turn on the phone. As soon the phone comes on and the green light turns off press RIGHTARROW, 0, 0. The phone will ask for the "FSC Code", press 000000 then choose OK and press RIGHTARROW, RIGHTARROW. Your phone is now in test mode. 2) The signal strength is the number on the top right hand side of the screen. 3) To turn off test mode shut of the phone and then turn it back on. <> Motorola 7760, 7860, 2260, 8160, etc Nam Programming : Nam Set: Fcn,0000000000000, Rcl Nam Set: 7466 3 #, Fcn, Fcn Test Mode: Fcn, 00**83786633, Sto Motorola v60c, v120c etc Nam Programming : Nam Set: 74663#, Menu, Menu, Spc Nam Set: Menu, 073887, * (type quickly) Test Mode: Menu, 073887*, Spc Debug Mode: ##33284 Force the phone into DIGITAL ONLY mode: 1) ##33284 (Debug) 2) RIGHT Softkey (Next) Twice 3) Down arrow 10 times to "PrefMod" 4) RIGHT Softkey (Change) until you see "DigOnly" 5) LEFT softkey (Exit) 6) MENU then LEFT Softkey return to idle screen 7) ##33284 (The last 4 will not display if you have done it correctly) Motorola t182, c210, etc Nam Programming : Nam Set: ##1111 end Nam Set: ##298645665 end Short Nam: ##073887 sto Motorola v710, v730, v740, ms150, etc Nam Programming : Nam Set: 8378*# + press 3 times NATE (spc - 071082) Test Mode: Menu, 073887*, Spc Service Menu: #758353266#646# Motorola StarTac 2004 Nam Programming : Nam Set: 5759789*#, rec key (3)times (spc - 915037) Motorola ms200, ms230, etc Nam Programming : Nam Set: 5759789*# (spc - 915037) Motorola v6060 Nam Programming : Nam Set:147*369#456*0# Motorola Razr V3C Nam Programming: Nam Set: 74663 # clr clr Nam Set: #073887* , then SPC MOTOROLA TEST MODE : v60, c120, c331, etc: 1) Turn on the phone. Press MENU 0 7 3 8 8 7 * 2) The phone will require you to "Enter a Security Code", press 000000, OK 3) Scroll down to "Test mode" choose SELECT. Scroll down to "Enable" choose SELECT. Your phone is now in test mode. 4) Signal strength is the 3_rd number down on the left hand side of the screen. 5) To toggle between regular mode and test mode: Press MODE then quickly press the BUTTON DIRECTLY TO THE LEFT OF MENU. 6) To turn off the test mode the phone must be in regular mode, then follow the above sequence and scroll down to where it says "DISABLE" instead of "ENABLE" and choose select. Motorola Bible - bible.txt <> lgc-300, etc Nam Programming : Nam Set: Menu, 9, Spc A-key: Press "Sto" 3sec, 2539** lgc-330w, etc Nam Programming : Nam Set: Menu, 4, 0, Spc A-key: 2539** lgc-510, v111, etc Nam Programming : Nam Set: Menu, 3, 0, Spc A-key: 2539** lgc-500, 800w, etc Nam Programming : Nam Set: Menu, 9 , 0, Spc Debug Mode: Menu, 7, 0, Fsc Debug Mode: Menu, 8, 0, Fsc A-key: 2539** Lg LX,VX-series, VX4400, VX6000, etc Nam Programming : Nam Set: ##Spc Nam Set: Menu, 0 Advanced Settings: ##2342 Vocoder: ##8626337,ok CAI Change: ##7738,ok Enable TTY: ##889,ok A-key: ##2539,ok Reset (Life time, Clear Memory, etc): ##786,ok <> Sky All Models Nam Programming : Nam Set: #7583538324#626# Nam Set: *759#364*7388464# Min simple mode: #758353266#646# Irm simple mode #758353266#476# Voice memo: #8767#277# Test Mode: #7583538324#8378# A-key: #758353266#2539# Service Menu: Menu+4+0+Spc Service Menu: Menu+5+0+Spc <> Withus wce-100, 200, 300, etc Nam Programming : Nam Set: ##948487+Save Nam Set: ##948482+Save Nam Set: ##66835+Save SMS Settings: ##76766 NVM Rebuild: ##777464 <> ENJOY N POST THE RESULT...... | |
The Following User Says Thank You to octopus_mobile For This Useful Post: |
01-19-2011, 10:13 | #1915 (permalink) |
Junior Member Join Date: Dec 2010 Location: muntinlupa MM, PHILIPPINES
Member: 1480076 Status: Offline Thanks Meter: 0 | help!! unlock motorola i880 sir! can u help me unlock my motorola i880? i dont have anygadget for motorola unlocking,all i have is ufs tornado old version and mxkey. im newbie on cellphone repaire. this is the imei number: 001700007842710 model number: h94xah6rr4an serial number:364vgsfn3q |
01-27-2011, 11:03 | #1917 (permalink) |
Insane Poster Join Date: Oct 2010 Location: palavanthangal,chennai
Member: 1409087 Status: Offline Thanks Meter: 3 | w230 head phone solution plz help me [email protected] send me |
01-30-2011, 10:51 | #1918 (permalink) |
Freak Poster Join Date: Apr 2009 Location: kushtia_BANGLADESH
Member: 1002743 Status: Offline Sonork: [email protected] Thanks Meter: 24 | help me moto-c200 help me c200 auto chirging when i put charger in off mood set show chirging but cannot complit and when i remuve charger but chirging cannot stop. and the set cannot on fully when it power on show moto logo and stop but power off. |
02-01-2011, 15:37 | #1919 (permalink) |
Junior Member Join Date: Nov 2010 Location: mumbai Age: 39
Member: 1454737 Status: Offline Sonork: [email protected] Thanks Meter: 10 | Motorola E6 Rocker how to remove security code i have Mss box But no idea to use plz help!!!!!!! |
Post here any problem about Nokia keypad - key, and let me give you the solution | stefani | Nokia Repair Guide and FAQ | 850 | 08-22-2013 12:05 |
Post me a problem in NOKIA and get it solved. | Shmona | Nokia Hardware & Hardware Repair | 6 | 12-31-2007 09:17 |
Like allways, NsPro give you THE BEST, FASTEST and of chourse.. the REAL!!! solutions | Elco | NSPRO | 73 | 04-25-2007 16:18 |
