Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing. |
07-07-2007, 08:40 | #556 (permalink) |
Freak Poster Join Date: Sep 2005 Age: 50
Member: 178616 Status: Offline Thanks Meter: 90 | l6 signal |
07-07-2007, 17:40 | #557 (permalink) |
Freak Poster Join Date: Apr 2003 Location: PORTUGAL Age: 73
Member: 27323 Status: Offline Thanks Meter: 8 | V 1075 Hi dear friend, I have a problem with this model. When I try to connect to the Smart Clip it gives this "AT COMMAND ERROR" I know that is because security code is active and someone had changed it! And it is also in "CONTCT RETAILER", because had exceeded all attempts to insert the code of the operator. In other models, I decided this problem in the following way: 1. power on the phone with any SIM 2. when it asks for user code, press MENU button 3. then it will ask for security password, enter 000000 and press OK (000000 - default security password. It might not be accepted, in case it was modified by user) 4. now you should be able to perform a Master reset & Master clear from the menu Who helps me? |
07-19-2007, 12:26 | #564 (permalink) |
Freak Poster Join Date: Jul 2007 Location: some where Age: 41
Member: 545608 Status: Offline Thanks Meter: 25 | v 3 key pad problem remove the top cover where the screen located and check the speaker flex where the volume button and the recording button maybe they r not in there corect position |
07-19-2007, 12:52 | #566 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 306903 Status: Offline Thanks Meter: 19 | hi ! i've a V3i and the problem is as soon as i switch it on it comes on and after 5 to 10 seconds goes off. I've flashed it plenty of time with different flash packs but still same problem. What problem could it be ? pls help me out to sort this out i'd be thnkful to u. WBR., .::ALi_110::.. |
Post here any problem about Nokia keypad - key, and let me give you the solution | stefani | Nokia Repair Guide and FAQ | 850 | 08-22-2013 12:05 |
Post me a problem in NOKIA and get it solved. | Shmona | Nokia Hardware & Hardware Repair | 6 | 12-31-2007 09:17 |
Like allways, NsPro give you THE BEST, FASTEST and of chourse.. the REAL!!! solutions | Elco | NSPRO | 73 | 04-25-2007 16:18 |
