Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Hardware Repair
Motorola Hardware Repair here all threads Related to Motorola Hardware Servicing and Repairing.
Old 06-08-2006, 20:20   #1 (permalink)
Member: 174505
V3r Invalid Battery
I have i pcs who show on display Invalid Battery ..... Please help me with any idea.
The metal shield was removed with hot air, maybe to make test point for unlock.
The battery is good because I check it with another phone.
Thanks in advance
Old 06-09-2006, 18:44   #2 (permalink)
Member: 66993
Thanks Meter: 12
I have the same problem, after removing metal shield, i have message "invalid battery" Please give us solution with picture.
Thx and regards.
Old 06-09-2006, 19:13   #3 (permalink)
Crazy Poster
Member: 158998
Thanks Meter: 2
and i had too same prob,with v3, i giv flash higer v, phone was charging and working normaly but after 2 dayes still has message on the display,"invalid battery" but i am never removing metal shield for this phone, any solution? thanks
Old 06-09-2006, 20:07   #4 (permalink)
fonefun's Avatar
Member: 26187
Sonork: 100:77458
Thanks Meter: 290
the problem with theses phone is the main processor has gone
thats what invalid battery is
Old 06-09-2006, 20:11   #5 (permalink)
..:: i-MAX ::..'s Avatar
Member: 94762
Thanks Meter: 115
try to clean testpoint area
Old 06-09-2006, 20:11   #6 (permalink)
BCcommunication's Avatar
Member: 76456
Sonork: 100.1678368
Thanks Meter: 60
find L6 or L7 invalid battery in forum and given pic here i think u help that pic
The Following User Says Thank You to BCcommunication For This Useful Post:
Old 06-09-2006, 20:16   #7 (permalink)
Member: 76456
Sonork: 100.1678368
Thanks Meter: 60
http://forum.gsmhosting.com/vbb/showthread.php?t=297157
try it and reply me
Old 06-10-2006, 00:33   #8 (permalink)
Member: 66993
Thanks Meter: 12
I cleaned testpoint area, and no succes. But i dont see any damage around Testpoint. But L6 phone is other then v3, then how can I compare it?
Old 06-10-2006, 00:34   #9 (permalink)
Member: 247488
do not waste ur time trouble shotting,just change the battery,the battery is bad.It also happens in V66.
Old 06-10-2006, 00:35   #10 (permalink)
Member: 247488
hallar try this and reply me ,[email protected]
Old 06-10-2006, 10:00   #11 (permalink)
Member: 66993
Thanks Meter: 12
I changed few battery and still have the same problem I found on forum something like that :
"i solved this problem on my v3, replace CR92
if the problem persist then need to replace U900"
What u think about this?
Old 06-11-2006, 11:30   #12 (permalink)
Member: 174505
I try this but nothing happened .... any idea ?
Old 06-11-2006, 22:07   #13 (permalink)
Member: 66993
Thanks Meter: 12
I also found something like that:
"if no is problem batery, change filter vr1201, it is very near lcd conector in pcb. works 100%"
Old 07-21-2006, 18:41   #14 (permalink)
cover_one's Avatar
Member: 97299
Thanks Meter: 43
that it's on V3 but what about V3R ?! any ideea how to solve the invalid battery on V3R ?
br
The Following User Says Thank You to cover_one For This Useful Post:
Old 07-29-2006, 05:03   #15 (permalink)
Member: 190774
you should not remove shield through hot air. i just cut a hole above the testpoints using slide cutter. that's the safest way.
® V3r invalid batt solution >>>>> ..:: i-MAX ::.. Motorola Hardware Repair 21 07-07-2009 10:55
v3r a.52 invalid battery =( Not hardware malfunction help =/ japooneis Smart-Clip 3 11-24-2008 08:29
V600/360/300 Invalid Battery with Generic Battery jim.mahoney Motorola P2k 4 09-07-2007 14:37
V3R invalid BATT after unlock! blue_life1111 Smart-Clip 2 07-06-2006 08:02
V3r Invalid battery please help spinchik Motorola P2k 6 06-17-2006 17:18
Page generated in 0.24561 seconds with 10 queries
