V3r Invalid Battery I have i pcs who show on display Invalid Battery ..... Please help me with any idea. The metal shield was removed with hot air, maybe to make test point for unlock. The battery is good because I check it with another phone. Thanks in advance |
I have the same problem, after removing metal shield, i have message "invalid battery" Please give us solution with picture. Thx and regards. |
and i had too same prob,with v3, i giv flash higer v, phone was charging and working normaly but after 2 dayes still has message on the display,"invalid battery" but i am never removing metal shield for this phone, any solution? thanks |
the problem with theses phone is the main processor has gone thats what invalid battery is |
1 Attachment(s) try to clean testpoint area |
find L6 or L7 invalid battery in forum and given pic here i think u help that pic |
I cleaned testpoint area, and no succes. But i dont see any damage around Testpoint. But L6 phone is other then v3, then how can I compare it? |
do not waste ur time trouble shotting,just change the battery,the battery is bad.It also happens in V66. |
hallar try this and reply me ,[email protected] |
I changed few battery and still have the same problem :( I found on forum something like that : "i solved this problem on my v3, replace CR92 if the problem persist then need to replace U900" What u think about this? |
I also found something like that: "if no is problem batery, change filter vr1201, it is very near lcd conector in pcb. works 100%" |
that it's on V3 but what about V3R ?! any ideea how to solve the invalid battery on V3R ? br |
you should not remove shield through hot air. i just cut a hole above the testpoints using slide cutter. that's the safest way. |
