for some reasons I dont think v3 is the sam pcb than v3r, at least, I cant find those points which should be connected to ground for fixing the invalid battery problem any suggestion ? the big ans shiny piece between the flex connector and the battery connector is broken, I tried to rehot it and now the phone wont power on, so the piece is now totally broken. |
http://C:\Documents and Settings\Adm...p's\v3.jpg use ubl magic test point is easy way heat and other termal thing may coz damage of flex and cpu. |
1 Attachment(s) this test point v3 use ubl magic test point or remove the shield very carefully |
for invalid battery it's always comes from the power management just reflow it and it will work good |
HOLA AMIGO!! de casualidad no tenes una foto en la que marques los componentes!! gracias!! |
v3 problem invalid batt not v3i plz give solution......... |
just try to use other original batteries brothers |
