02-11-2006, 17:35 | #1 (permalink) |
Freak Poster Join Date: Oct 2005 Age: 36
Member: 187541 Status: Offline Thanks Meter: 0 | 3230 flash problem urgent! BR dd |
02-11-2006, 20:49 | #4 (permalink) |
Member: 187541 Status: Offline Thanks Meter: 0 | it doesn't work. if flash it by nornal dct4 with disable vpp, it goes like this: Processing File: RM51PE405370.C1 Boot... ASIC ID: 1081 WD2 BT2 w3_2nd.fia w3_amd.fia Configuration Info (9F): Number of Flashes: 4 00000000: Amd, 0001 007E 0016 0111, 10 02000000: Amd, 0001 007E 0016 0111, 10 04000000: Amd, 0001 277E 0002 0111, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA Erase[26.81 MB]... request erase [00000000 to 0000FFFF] request erase [00010000 to 00FFFFFF] request erase [02000000 to 02A9FFFF] request erase [02FC0000 to 02FEFFFF] Waiting response for 600 Sec... %%%%%%%% ERROR ERASING: Failed at address FF000000 if flash with slow dct4, goes like this: Processing File: RM51PE405370.C1 Boot... ASIC ID: 1081 WD2 BT2 w3_2nd.fia w3_amd.fia Configuration Info (9F): Number of Flashes: 4 00000000: Amd, 0001 007E 0016 0111, 10 02000000: Amd, 0001 007E 0016 0111, 10 04000000: Amd, 0001 277E 0002 0111, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA Erase[26.81 MB]... erasing region [00000000 to 0000FFFF] erasing region [00010000 to 00FFFFFF] %%%%%%%% ERROR ERASING: Failed at address 00030000 if try to erase mannually, like this: Custom Erase Areas: 00000000 - 0000FFFF (0.062499 MB) 00010000 - 00FFFFFF (15.937499 MB) 02000000 - 02A9FFFF (10.624999 MB) 02FC0000 - 02FEFFFF (0.187499 MB) 00000000 - 0000FFFF (0.062499 MB) 02B00000 - 02EFFFFF (3.999999 MB) 04600000 - 0471FFFF (1.124999 MB) Operation will continue aproximately 330 seconds, please wait... WD2 BT2 w3_2nd.fia w3_amd.fia Erasing: 00000000:0000FFFF Erasing: 00010000:00FFFFFF Operation failed with error 0006, addr 00030000 any idea what's wrong with this?thanks BR dd |
02-12-2006, 12:20 | #9 (permalink) |
Member: 187541 Status: Offline Thanks Meter: 0 | is possible the cable problem? i use the 6260 cable, i need to push the clip on the back when i unlock or flash. though the cable is not exactly for 3230 but it works perfect on unlocking. also i can use this cable flash 3230 by twister. really need help, i need to know what the problem is, the phone is totaly dead now BR dd |
08-16-2006, 18:49 | #11 (permalink) |
Insane Poster Join Date: Apr 2004 Age: 48
Member: 61861 Status: Offline Thanks Meter: 2 | 3230 Flashing With MT-Box Versiom 1.23 Problem & need help?? Here is the detail when doing flashing. After flash phone with white screen display and turn off automatically after few second. "I already turn off the VPP and set to SLOW DCT4 Setting" VPP is DISABLED. Processing File: RM51PE506140.C2 Boot... ASIC ID: 1081 WD2 BT2 w3_2nd.fia w3_amd.fia Configuration Info (9F): Number of Flashes: 4 00000000: Samsung, 00EC DDFE 0000 0121, 10 02000000: Samsung, 00EC EEFE 0000 0121, 10 04000000: Samsung, 00EC 2250 0000 0121, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA Erase[29.12 MB]... erasing region [00000000 to 0000FFFF] erasing region [00010000 to 00FFFFFF] erasing region [02000000 to 02CEFFFF] erasing region [02FC0000 to 02FEFFFF] in 195.75s Flash[28.95 MB]...in 151.64s * * Processed file in 363.61 seconds Processing File: RM51PE506140.85 Boot... ASIC ID: 1081 WD2 BT2 w3_2nd.fia w3_amd.fia Configuration Info (9F): Number of Flashes: 4 00000000: Samsung, 00EC DDFE 0000 0121, 10 02000000: Samsung, 00EC EEFE 0000 0121, 10 04000000: Samsung, 00EC 2250 0000 0121, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA Erase[4.69 MB]... erasing region [00000000 to 0000FFFF] erasing region [02D00000 to 02EFFFFF] erasing region [04600000 to 047FFFFF] erasing region [02F00000 to 02F9FFFF] in 32.92s Flash[4.65 MB]...in 24.64s * * Processed file in 73.81 seconds * * * Phone flashing done in 7:19 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! |
08-18-2006, 09:04 | #13 (permalink) |
Member: 61861 Status: Offline Thanks Meter: 2 | I already try all the newer version, still can't power on the phone? Any suggestion? VPP is DISABLED. Processing File: XXXXX(new version) Boot... ASIC ID: 1081 WD2 BT2 w3_2nd.fia w3_amd.fia Configuration Info (9F): Number of Flashes: 4 00000000: Samsung, 00EC DDFE 0000 0121, 10 02000000: Samsung, 00EC EEFE 0000 0121, 10 04000000: Samsung, 00EC 2250 0000 0121, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA Erase[26.81 MB]... erasing region [00000000 to 0000FFFF] erasing region [00010000 to 00FFFFFF] erasing region [02000000 to 02A9FFFF] erasing region [02FC0000 to 02FEFFFF] in 179.91s Flash[26.65 MB]...in 139.64s * * Processed file in 336.02 seconds Processing File: RM51PE506140.32 Boot... ASIC ID: 1081 WD2 BT2 w3_2nd.fia w3_amd.fia Configuration Info (9F): Number of Flashes: 4 00000000: Samsung, 00EC DDFE 0000 0121, 10 02000000: Samsung, 00EC EEFE 0000 0121, 10 04000000: Samsung, 00EC 2250 0000 0121, 10 06000000: NotUsed, 0000 0100 0000 0000, 0 ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA Erase[4.50 MB]... erasing region [00000000 to 0000FFFF] erasing region [02B00000 to 02EFFFFF] erasing region [04600000 to 0466FFFF] in 30.08s Flash[4.50 MB]...in 23.66s * * Processed file in 69.97 seconds * * * Phone flashing done in 6:48 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! |
10-05-2006, 12:42 | #14 (permalink) |
Insane Poster Join Date: Jun 2006 Location: cold mountain
Member: 295823 Status: Offline Thanks Meter: 7 | dead 3230, booting problem with mt-box v1.23 To Griffin Team: Can u help me with this problem, I flash it with v1.23, i tried different flash files and still got this problem.. Processing File: RM51PE405370.C1 Boot... ASIC ID: 1081 WD2 BT2 w3_2nd.fia %%%%%%%% ERROR BOOTING: |
nokia 3230 network problem.. urgent | paragonpcc | Nokia Hardware & Hardware Repair | 4 | 04-04-2007 19:57 |
3230 flashing problem with JAF | fone | Nokia Hardware & Hardware Repair | 2 | 09-04-2006 15:17 |
3230 flashing problem | fahaad | Nokia Hardware & Hardware Repair | 9 | 12-23-2005 12:35 |
3230 flashing problem | foony | Phoenix Black Box | 4 | 06-13-2005 23:01 |
