01-21-2006, 21:22 | #1 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Algeria Age: 41
Member: 26438 Status: Offline Thanks Meter: 8 | 6600 NHL-10 PROTO (prototype) I received one Nokia 6600 for flashing, so I flashed, at the end, phone won't power on! I checked infos under battery and I find this: ---------------------------------- Model: XXXX Type: NHL-10 IMEI: 004400----------- (15 igits) PROTO NPl 1.0 Proprety of Nokia Not for sale! ---------------------------------- Phone was working before and showing version 2.35. Now dead, flashed with last v5.53!!! Anyone here have solution to revive it? Any special flash for this PROTOtype model, maybe v2.35 will do the trick! Thanks in advance. |
01-23-2006, 20:56 | #2 (permalink) | |
No Life Poster Join Date: Dec 2002 Age: 47
Member: 18855 Status: Offline Thanks Meter: 1,938 | maybe try to flash with the old version Quote:
01-23-2006, 21:38 | #3 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: HUR / R.S Age: 39
Member: 21750 Status: Offline Sonork: 100.62509 Thanks Meter: 73 | Quote:
01-24-2006, 07:18 | #5 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: S7°1x'xxx" - E112°4x'xxx"
Member: 128035 Status: Offline Thanks Meter: 317 | Quote:
01-24-2006, 10:03 | #6 (permalink) | |
Member: 26438 Status: Offline Thanks Meter: 8 | Quote:
But this 6600 proto is diffrent hardware from 6600 normal, it has special flash! Some people said that I have to flash it with 3650 flash, I do it, 6600 proto turn on, only white screen, and keypad beep, but it doesn't work! So solution is in this msusw 2.35!!! Anyone have it??? About 6630 N70 proto, maybe it's not same thing with the 6600 proto. @ A.... I search in forum and found nothing! | |
01-31-2006, 07:08 | #7 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Bulgaria Age: 53
Member: 5579 Status: Offline Thanks Meter: 5 | Hi,here same problem with proto 6600.I checked that phone is proto,but version was 3.42.1,so i flashed PPM only,but even after that phone died.Tried full erase and after that flash but still phone dead.Maybe any not standard organisation of flash memory chips?Cause as i see at start of Griffin inside are AMD flash chips - 0001007E. |
03-10-2006, 06:25 | #9 (permalink) | |
NGage - NEM-4 ver 1.0 mcusw 4.17 - POS DEMO SW 6680 - RM-36 ver 1.00 mcusw 1.23.22 - IMODE | |
6600 nhl-10 | pakmobiles | WD2 & APE (Symbian Phones) | 7 | 01-24-2007 13:52 |
nokia 6600 nhl-10 v3.49 | The Racer | Griffin | 1 | 03-26-2004 23:01 |
Flash 6600 NHL-10 with chinese flash?? | epic | Nokia Digital Core Technology 4 ( DCT-4 ) | 24 | 02-23-2004 03:48 |
info Nokia 6600 nhl-10 | miroservice | WD2 & APE (Symbian Phones) | 1 | 12-15-2003 12:34 |
