12-08-2007, 18:39 | #1 (permalink) |
Registered User Join Date: Feb 2004 Location: MERSIN, TURKEY
Member: 55026 Status: Offline Thanks Meter: 53 | After upload RPL 6230i turn off in 40 sec.!!! regards. |
12-08-2007, 19:15 | #2 (permalink) |
No Life Poster Join Date: Aug 2004 Age: 47
Member: 76257 Status: Offline Thanks Meter: 77 | check for right type of asic in file or use preloaded rpls in whatever software u are using if thats ok then make sure the properties of the file bieng are archieved before u write them to phone thats it --regards-cpukiller |
12-13-2007, 10:00 | #10 (permalink) |
Member: 55026 Status: Offline Thanks Meter: 53 | it is very interesting! I changed CPU,Flash, fully erased. the same! I will try to change uem again or I will use this uem for another phone and test.. regards. |
12-13-2007, 10:33 | #11 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | mate when you change uem with new and power on the phone ,phone need to stay powered nto to off after 30sec. if after change uem with new (before write to phone any RPL) phone power off then uem is not ok! |
12-13-2007, 19:26 | #13 (permalink) | |
Member: 55026 Status: Offline Thanks Meter: 53 | Quote:
This is very interesting.. I have never seen.., now I will erase all sectors with MT-BOX and do as xiakaijun mantioned.. if no result I will solder the same uem to another phone.. then psot result.. regards.. | |
12-13-2007, 19:45 | #14 (permalink) |
Member: 55026 Status: Offline Thanks Meter: 53 | now! I found out something very interesting.. when I try to read field 208 it gives me 0 bytes. no bytes can be readed from this erea.. here is a pm readed by ufs; Reading PM: 200-215 Id: [200] 1 Record(s) Record: 0, 5 byte(s), Ok Id: [202] 0 Record(s) Id: [205] 0 Record(s) Id: [206] 0 Record(s) Id: [208] 0 Record(s) Id: [209] 0 Record(s) Id: [210] 0 Record(s) Id: [211] 0 Record(s) Id: [213] 1 Record(s) Record: 0, 20 byte(s), Ok Id: [215] 0 Record(s) PM Read Done 2 Record(s), Time: 00:00 many fields are emty, I did not change nand flash, as I know field 208 is in main flash..but I changed it 2 times.. really very interesting... |
nokia e63 after unlock turn off in two minutes | sweet.baspi | Nokia Hardware & Hardware Repair | 8 | 03-01-2010 15:43 |
6230i turns off immediately | shaun-the-sheep | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 07-26-2008 15:32 |
6230i turns off | ziober | Nokia Hardware & Hardware Repair | 0 | 08-07-2006 15:55 |
