02-21-2008, 21:53 | #1 (permalink) |
Insane Poster Join Date: Jul 2005 Age: 39
Member: 159655 Status: Offline Thanks Meter: 7 | Mt Box doesnīt power atc and all the three boxes canīt give power for any mobile. please any onde can solve my problem? |
02-25-2008, 20:50 | #5 (permalink) |
Junior Member Join Date: Feb 2005 Location: Cracking your brain Age: 36
Member: 116432 Status: Offline Thanks Meter: 0 | I have a similar problem, phone enter test mode 1 to 10 attempts, I use cable of 10 pins... The cable has a resistor 5.1K tomorrow chage for 7.5 how say here http://forum.gtibox.net/showthread.php?t=6 It is original from Ipmart ... Bye |
02-27-2008, 22:44 | #6 (permalink) |
Member: 159655 Status: Offline Thanks Meter: 7 | itīs not that. again, the problem is that mt-lite does NOT provide 4v in order to phone turn on. itīs not cable problem, itīs not attempt problem or anythinhg like that. pin1 on mt-box nokia does NOT have 4v, thatīs the issue. |
02-27-2008, 22:50 | #7 (permalink) | |
No Life Poster Join Date: Mar 2004 Location: Athens - Greece
Member: 59935 Status: Offline Thanks Meter: 131 | Quote:
From where you bye this boxes ? Are they working before ? Try to contact GT911. or tell us more there .. I'm shure with reading much more this forum you will find solution . !!! Don't worry . BR baboom Did you try with external power (Nokia charger) with usual F-bus cable ? (MT-box ) 1st be shure if MT-box is working well b4 connect MT-lite !!! Last edited by baboom; 02-27-2008 at 22:57. Reason: P.S. | |
02-28-2008, 05:32 | #10 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: tamilnadu, india.
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | Quote:
whether all pins even and not damaged one... and also try with some 10 pin cables.....then also same means just return to your reseller... | |
02-28-2008, 05:44 | #11 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Gujjar AJK
Member: 207308 Status: Offline Thanks Meter: 471 | MT-Lite connector problem i change this with new and now never problem but one thing in new version some time software not open untill 2 or more than 2 time box reconnect its a bug or window/PC problem plz but when soft open works absolutely 100% ok |
02-29-2008, 03:59 | #12 (permalink) |
Member: 159655 Status: Offline Thanks Meter: 7 | thanks to all that tried to help, but again, you did NOT read my posts... "itīs not that. again, the problem is that mt-lite does NOT provide 4v in order to phone turn on. itīs not cable problem, itīs not attempt problem or anythinhg like that. pin1 on mt-box nokia does NOT have 4v, thatīs the issue." - it clearly states the problem is NOT faulty cable, so donīt bother saying anything about. Itīs not. - iīm not talking about "auto entering test mode" or anything like that. Iīm saying that pin1 DOES NOT have 4.10v like it was supposed to. - of course acp-12u or acp-12ub was connected. but again, ppl does not seem to understand that charger will only help to feed power to phone, but pin1 gotta have 4.10v all the time mt software is running, even when phone is not connected. - of course box used to work before. otherwise, weīd be looking for replacement, not for a hardware fix. - again, the problem is NOT with mt-lite, but with mt-nokia, which DOES NOT provide the usual 4.10v anymore - i work for the reseller, giving him the box wonīt make any change. anyway, all these boxes are out of warranty time, so they canīt be replaced. and each day, more ppl having same problem, and no solution Iīve seen worked. replacing the coils, r25, d8, c19 or even the arm atmel makes no change. - 2 more mt-nokia with same problem returned from our customers. it makes 6 mt-nokia half-dead, and a lot of other customers are looking for us in order to get their boxes repaired. @ baboom 911GT ignored all mails sent to him, so I donīt think he can/want to help. @ harim_1981 in order to say that pin1 does not have the 4.10v, of course pins were checked. itīs pointless to look at mt-lite connector, if power is not fed by mt-nokia. @ S I M seems like you have the same problem, so please donīt let this topic die until we find the cause. not powering phone, not entering test mode etc is only a symptom. @ adn****i box not opening at first time: problem with some kind of debugger being detected, or faulty smart-card reader. |
02-29-2008, 09:28 | #13 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | this problem is not for Private messages!! About that i dont answer to you on a PM!!I have more of 200 PM messages for things who is not for PM!!!! When box or adapter dont work correct and you cant solve this problem without open it ,and box or adapter is in warranty yhen return to reseller for a change |
MT Box (Nokia) Activated with MT Box (Siemens) Functions & BB5Act + 6 pcs MT Box (SE) | IPMART | ipmart WebShop | 0 | 11-17-2008 13:10 |
MT box Nokia+Siemens, NFF box, Padfinder Full, Padfinder Lite, Power Sim Lite | Gsmserver | Main Sales Section | 0 | 05-27-2008 13:09 |
Mt-box Nokia & Mt-box Sonyerr. == Mt-box Total | kalpeshoza | MT-BOX | 2 | 04-25-2007 07:39 |
Mt-Box Donīt power on | marcvaz | MT-BOX | 12 | 01-28-2006 08:35 |
@ MT-Box team Please help V902sh (japan) not power On after Mt-box | bedjo | MT-BOX | 1 | 11-22-2005 11:30 |
