07-15-2007, 20:57 | #1 (permalink) |
No Life Poster Join Date: May 2006
Member: 276432 Status: Offline Thanks Meter: 65 | is this cable mt n95 connection correct for flashing this is the connection schema of my circuit , please if any one can help me to see the wrong in this circuit. notes in the schema: 1- we didn't connect he gray cable. 2- change the node which connected to Vpp. 3- connect the floating node to GND. please see the attached cable connection to give me an advice. [/IMG] |
07-17-2007, 00:55 | #4 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Hong Kong
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Right, the cable must be connected directly to MT box not by using adapter. Your N95 cable must have 10 pins on the side which need to be connected to box. |
07-18-2007, 00:31 | #7 (permalink) |
Member: 276432 Status: Offline Thanks Meter: 65 | aha so what is the error the jaf and mt cann't erase nokia n95 both gave me the same error mt : error booting jaf: cmd boot loader not found but 2 boxs flash the phone good so why n95 we cann't erase until now |
07-18-2007, 09:23 | #8 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | man please do cable like on a shematic and try if dont work then phone is not ok . to me all is ok . to another 100 people all is ok only to you is not. find error in you . check all again, see warnning all automatic and option functions in soft and try again. |
07-26-2007, 18:04 | #9 (permalink) |
No Life Poster Join Date: Jan 2004
Member: 51125 Status: Offline Thanks Meter: 1,435 | MTBOX: 0034234f27 - Nokia Flash/Repair v1_34 Box: CR V 1.002 256 Code: NK V 1.001 1046 SN: 0034234f27 Nokia Unlimited: 117 times started SonyEricsson Trial: 10 left, each max 15min Processing File: RM159_10.0.010_022_U01_uda.fpsx Boot... FAILED TO BOOT PHONE!!! Make sure that phone is connected. Processing File: RM159_10.0.010_022_U01_uda.fpsx Boot... RAPIDOv102_2nd.fg RAPIDOv11_algo.fg omap2420_m1_2nd.fg RAPIDOv102_2nd.fg RAPIDOv11_algo.fg omap2420_m1_2nd.fg %%%%%%%% ERROR BOOTING: the jaf and mt cann't erase nokia n95 both gave me the same error mt : error booting jaf: cmd boot loader not found but 2 boxs flash the phone good so why n95 we cann't erase until now |
07-30-2007, 15:54 | #10 (permalink) |
Member: 51125 Status: Offline Thanks Meter: 1,435 | MTBOX: 0034234f27 - Nokia Flash/Repair v1_35 Box: CR V 1.002 256 Code: NK V 1.001 1047 SN: 0034234f27 Nokia Unlimited: 174 times started SonyEricsson Trial: 10 left, each max 15min ============= Set Flash mode for info ============= VBat is 3.98V Vpp pin has 1.28V, Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Boot... RAPIDOv102_2nd.fg RAPIDOv11_algo.fg omap2420_m1_2nd.fg Failed to boot send APE 2ND (bad APE) Phone Type: BB5 ------------------- SYSTEM ID Response: 11 blocks ------------- SYSTEM_ASIC_ID( APE ): 24200705 ASIC_MODE_ID( APE ): 00 PUBLIC_ID( APE ): D5909DC0F9EADFAD40DB41F362A73C69A4C46672 ROOT_KEY_HASH( APE ): BA8710A7E1CD5A2909B9A875DB27AA2400000000 SYSTEM_ASIC_ID( RAP ): 000000010000022600010006400C192101011103 EM_ASIC_ID( RAP ): 00000295 EM_ASIC_ID( RAP ): 00000B21 PUBLIC_ID( RAP ): 15200007514F0058F509525C10B165A10D58A593 ASIC_MODE_ID( RAP ): 00 ROOT_KEY_HASH( RAP ): CAEEBB65D3C48E6DC73B49DC5063A2EE ROM_ID( RAP ): F2C6EBADC86E6189 --------------- Device ID Response: 3 blocks ------------- Storage Device: Owner Asic: RAP Type: NOR Flash Index: 0 Flash: Amd, 0001 0035 0000 6921 Storage Device Contents: Owner Asic: RAP 000000000000000000000000000000000000 ============= Set FBus mode for info ============= VBat is 3.93V Vpp pin has 1.30V, Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Scanning files, please wait... Done Selected Highest installed version: 12.0.013 Processing File: RM-159_12.0.013_PR.C0R Boot... RAPIDOv102_2nd.fg RAPIDOv11_algo.fg omap2420_m1_2nd.fg RAPIDOv102_2nd.fg RAPIDOv11_algo.fg omap2420_m1_2nd.fg %%%%%%%% ERROR BOOTING: Processing File: RM-159_12.0.013_PR.C0R Boot... RAPIDOv102_2nd.fg RAPIDOv11_algo.fg omap2420_m1_2nd.fg %%%%%%%% ERROR BOOTING: plss help me 911gt |
08-22-2007, 02:46 | #11 (permalink) | |
No Life Poster Join Date: Apr 2006
Member: 268887 Status: Offline Thanks Meter: 91 | Quote:
Can we buy a ready made cable for MT Box, which have TX2LINE connected as the cables I have just got 8 cables inside and not 10 so I can't modify them. | |
Is this Version of N95 RM-160 Supported for UNLOCK??? | aslam870 | Universalbox | 5 | 10-10-2009 14:37 |
where is this 6085 flip detector connections goes to ? | hooi76 | Nokia Hardware & Hardware Repair | 0 | 11-24-2007 07:12 |
is this cable mt n95 connection correct for flashing | dvdaio | MT-BOX | 0 | 07-15-2007 21:09 |
is this JDM with ISO scheme correct?? | YeTi | Sim Cloning and Scaning | 2 | 03-10-2004 13:39 |
what is this cable | dazexy | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 12-20-2003 12:48 |
