09-28-2007, 07:33 | #1 (permalink) |
Junior Member Join Date: Mar 2006
Member: 241270 Status: Offline Thanks Meter: 0 | cannot change 6233 v5.10 into local mode when i try to unlock a n73 and 6233 doesnt matter how i do it the phone cannot change into local mode. I found out that i can change any 6280 which have version 3.81 or below to local mode by using the mt -box software. and i also have no problem to change 6300 into local mode any idea? thx |
09-28-2007, 09:49 | #2 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | i thing you have a general problem with this software and box. what cable you try to use? what is state of phone when you connect it to box? post log from any phone many many question about this |
09-29-2007, 02:12 | #3 (permalink) |
Member: 241270 Status: Offline Thanks Meter: 0 | thx for the reply i follow the instruction from the user menu, and i am using the dku2 cable that come with the box the phone was switch off before i connect to the software. after i connect to the software the phone is still switch off. and when i press the power switch the phone just turn on in normal mode. so i try to use the mtbox sotware to try to change the mode to local. But the phone still in normal mode but when i use the cabe for 6300, the phone just jump to test mode with no problem. |
09-29-2007, 13:04 | #4 (permalink) | |
Freak Poster Join Date: Feb 2005 Location: Romania,Vietnam
Member: 119732 Status: Offline Thanks Meter: 31 | Quote:
2.some telefone have problem i had reflash and run OK | |
09-29-2007, 15:53 | #5 (permalink) |
Member: 409197 Status: Offline Thanks Meter: 75 | no mate, need connect dcu-2 cable with PRO but wihout battery! need connect dcu-2 botom of phone ,RED to + of battery terminal and green to BSI terminal then connect to adapter and pres shortly powe button. With battery phone never go to local or test mode |
N95 cannot go into local mode need to reset secuirty password help please | 07865 | Nokia Base Band 5 ( BB-5 ) | 11 | 01-05-2010 12:43 |
Ngage wont go into Local mode ..please help | sharkie2006 | Nokia Hardware & Hardware Repair | 3 | 06-03-2006 16:27 |
6230i Doesn't get into LOCAL MODE | sin_daemon | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 02-17-2006 00:56 |
When you aren't getting your 3650 into Local Mode | Mastah-GSi | Trisha & Matrix Flasher | 8 | 01-08-2004 01:41 |
