05-07-2007, 16:14 | #16 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Hong Kong
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | I press phone info but the files is not on Pcode menu. Answer: Install phone data package then restart MTB NK software Press phone info and now you will se language region info Customer: Yes i do this, but all is same Answer: Then go to C:\Program Files\GriffinTeam\MT-Box\ and open phoenix.ini in any text editor and add new model.For example want to add Nokia E65. [Products] BB5.0=NMP.Product.Menu.A.1 BR45=NMP.Product.Menu.A.1 BT-Accessory=NMP.Product.Menu.A.1 LITE1=NMP.Product.Menu.A.1 NEM-1=NMP.Product.Menu.A.1 NEM-2=NMP.Product.Menu.A.1 NEM-4=NMP.Product.Menu.A.1 NHL-2NA=NMP.Product.Menu.A.1 NHL-4=NMP.Product.Menu.A.1 NHL-4J=NMP.Product.Menu.A.1 NHL-4JX=NMP.Product.Menu.A.1 NHL-4U=NMP.Product.Menu.A.1 NHL-6=NMP.Product.Menu.A.1 NHL-8=NMP.Product.Menu.A.1 NHL-9=NMP.Product.Menu.A.1 NHL-10=NMP.Product.Menu.A.1 NHL-12=NMP.Product.Menu.A.1 NHM-1=NMP.Product.Menu.A.1 RM-208=NMP.Product.Menu.A.1 and on end of file add [RM-201] Description=Nokia 6178i [RM-154] Description=Nokia 6275/6275i [RM-180] Description=Nokia N72 [RM-189] Description=Nokia RM-189 [RM-190] Description=Nokia RM-190 [RM-170] Description=Nokia RM-170 [RM-171] Description=Nokia RM-171 [RM-208] Description=Nokia E65 Save changes Restart MTB NK software Press phone info and check it is all ok |
05-09-2007, 23:26 | #17 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Customer: I try to unlock DB2020 phone CID 49 but software give me warning that FLR file does not exist. How can i check this before make to unlock? Answer: - Power on the phone - Type >*<<*<* and go to service menu -> Service info -> Sim lock and check it is all lock opened (maybe someone are try to unlock it with some other solution and the phone now have all locks closed) - If all locks are closed , you cant help him (at the moment) - Now go to Software info menu and check phone software version for example K610: R1GB001 prgCXC1250374_GENERIC_TH - Now go to C:\Program Files\GriffinTeam\MT SonyEricsson\DB2020 inside\flr\K610\ and check its there found R1GB001 prgCXC1250374_GENERIC_TH.flr - If that is ok connect phone to cable and press phone info to see what phone CID is - If phone CID is 49 or CID 51 select from C:\Program Files\GriffinTeam\MT SonyEricsson\DB2020 inside\Unlock\DB2020Unlock.act - Press Do it button - Wait to software finish |
05-09-2007, 23:28 | #18 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Customer: I have account for DCT4+ can i use it for DB2020 unlock. Answer: We are sorry but Nokia only acounts cant be used for full server access included DB2020 unlock. |
05-09-2007, 23:29 | #19 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Customer: I check but FLR file does not exist for my phone software version. What can i do? Answer: In this case you need to flash your phone with desired language pack and then make unlock. |
05-09-2007, 23:29 | #20 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Customer: I first make unlock then change language, the phone is locked again. What i need to do? Answer: You need to unlock your phone again. |
05-09-2007, 23:32 | #21 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Customer: Can i use MT Box Nokia with DB2020 software? Answer: Yes you can use DB2020 unlock software with your box but only for limited time 10 x 15 minutes. After that Db2020 software cant be started and you need to buy MT Box SonyEricsson to able use SE software. |
05-09-2007, 23:38 | #22 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Customer: I lost 5 logs, can be refunded? Answer: Only in case server not work (like in December 2006 about 30 minutes), when many users report problems in same time. In this case we will analyze, solve the problem then refund all logs to customers who use it in that time. |
05-10-2007, 11:35 | #23 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Customer: How can i know that my Griffin server account can be used to unlock DB2020 or no? Answer: Start DB2020 inside software Go to Settings tab Enter your Griffin server login details Press info (internet connection required) Then your account details will be shown The details from account who don't have credits or login details is wrong: Connecting... The details from account who have access to Nokia services only and CANT be used or converted to/as full access account: Connecting... Available credits:965 Added Panasonic X700 and VS3 and Alcatel E-xxx Download lates version from www.griffinteam.net NK_DCT4_ASIC11 5 NK_DCT4_PLUS 5 --------------------- CREDIT COUNT: 965 The details from account who have have full access to Griffin server and can be used for all services: Connecting... Available credits:965 Added Panasonic X700 and VS3 and Alcatel E-xxx Download lates version from www.griffinteam.net Alcatel E801 10 Alcatel C 10 Alcatel E-xxx 10 Panasonic VS3 1 Panasonic X700 1 NK_DCT4_ASIC11 5 NK_DCT4_PLUS 5 NKUF 10 NKF 10 Panasonic_A100 1 SiemensC62_5 5 SiemensC62_4 5 SiemensC62_3 0 SiemensC62_2 5 SiemensC62_1 0 K700_2 5 K700_1 0 LG-81XX 1 LG C3100/C1200/C1100/7100/G7120 1 Sharp GX30/TM100 1 Siemens ST 60 1 Panasonic x60 1 NK ESN FLASH+UEM 10 Panasonic G50 1 Siemens ST 55 1 Panasonic GD55 1 LG-G7050 1 NK ESN FLASH 10 Maxon 797x 1 Maxon 792x 1 Panasonic x70 1 NK 7250i+FLASH+UEM 10 NK FLASH+UEM IMEI 10 NK 7250 to 7250i 10 NK FLASH IMEI 10 NK_BB5_PM_AUTH 0 NK_BB5_CERT_REST 40 MOTO_C139 1 --------------------- CREDIT COUNT: 965 Last edited by SoftMobile; 05-10-2007 at 11:47. |
05-10-2007, 18:09 | #24 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Customer: I try to unlock K800 CID 49 but without success. This is my log from software window: Power on the phone... Boot OK. PID:......99 00 03 01 FF FF FF FF IMEI:.....351708-01-xxx045 PAF:......01 CID(dec):.49 CID(hex):.31 MfrID0:...20 DevID0:...19 Color:....RED CID in FLASH(dec):52 CID in FLASH (hex):34 Processing: DB2020 Unlock Action error:2 Answer: The phone you try to unlock is upgraded to CID 52 and cant be unlocked by this method. |
05-10-2007, 18:14 | #25 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Customer: How i can check phone CID to know it is unlock able or not? Answer: Start DB2020 software Connect phone to cable and press Phone info button If you see info like this the phone is unlock able: Power on the phone... Boot OK. PID:......99 00 03 01 FF FF FF FF IMEI:.....351708-01-xxx045 PAF:......01 CID(dec):.49 CID(hex):.31 MfrID0:...20 DevID0:...19 Color:....RED CID in FLASH(dec):49 CID in FLASH (hex):31 Power on the phone... Boot OK. PID:......99 00 03 01 FF FF FF FF IMEI:.....351708-01-xxx045 PAF:......01 CID(dec):.49 CID(hex):.31 MfrID0:...20 DevID0:...19 Color:....RED CID in FLASH(dec):51 CID in FLASH (hex):33 Power on the phone... Boot OK. PID:......99 00 03 01 FF FF FF FF IMEI:.....351708-01-xxx045 PAF:......01 CID(dec):.51 CID(hex):.33 MfrID0:...20 DevID0:...19 Color:....RED CID in FLASH(dec):51 CID in FLASH (hex):33 If you see info like this the phone is NOT unlock able: Power on the phone... Boot OK. PID:......99 00 03 01 FF FF FF FF IMEI:.....351708-01-xxx045 PAF:......01 CID(dec):.49 CID(hex):.31 MfrID0:...20 DevID0:...19 Color:....RED CID in FLASH(dec):52 CID in FLASH (hex):34 Power on the phone... Boot OK. PID:......99 00 03 01 FF FF FF FF IMEI:.....351708-01-xxx045 PAF:......01 CID(dec):.51 CID(hex):.33 MfrID0:...20 DevID0:...19 Color:....RED CID in FLASH(dec):52 CID in FLASH (hex):34 The phones with info like this can be unlocked: CID in FLASH(dec):49 CID in FLASH (hex):31 CID in FLASH(dec):51 CID in FLASH (hex):33 The phones with info like this CANT be unlocked: CID in FLASH(dec):52 CID in FLASH (hex):34 |
05-11-2007, 13:28 | #26 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Customer: How to unlock DB2020 phone? Answer: Download and install DB2020 inside v1.9.exe Install the software Start software Enter your login details in Settings tab Press info to check it is all ok with your account Close Settings tab Power on your phone and check this info If all is ok, select DB2020unlock.act Press Do IT button Wait to software finish Because a lot of people has problem with USB drivers we recommend you to use box cable connected to MT box without Nokia adapter. |
05-17-2007, 16:25 | #28 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Customer: My phone is dead during unlock and software give me warning message" FLR not exists!!! CONTINUE ? ". Answer: You need to flash your phone and then unlock it. The phone will be fine after. How to check does FLR file exist for your phone |
08-06-2007, 16:16 | #29 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Customer: I got my RPL from GT server but its not good, can moderators check it, i am upload it here on forum. Answer: DO not post any ASK or RPL file on forum, its is not allowed. All messages which contain ASK or RPL (with phone imei) will be permanently deleted and user account for GT server suspended. If you have any problem with RPL, please contact user GT911 using PM (private messages) Thank you for understanding Last edited by SoftMobile; 08-08-2007 at 11:05. |
09-16-2007, 19:45 | #30 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Customer: How to solve N95 start up failed? Answer: THIS is erase file. 1st. MAKE BACKUP OF IMEI 2nd.READ FULL PM and save it 3th.Erase phone and flash it with vatest version. 4th.power on the phone and check in what condition is. If all is ok -phone work good write IMEI backup and after that from PM backup field 134,restart phone ,make sx4 authorization and write fields 1,135. |
F.A.Q., Contacts, Supported models, Cables/pinouts | InfinitySupport | Infinity-Box | 7 | 08-05-2015 15:57 |
[FAQ] FuriousGold - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! | .:hack3r2k:. | FuriousGold | 4 | 03-23-2011 08:03 |
F.A.Q - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! | Mohsin-* | FuriousGold | 0 | 11-10-2008 16:00 |
F.A.Q - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! | .:hack3r2k:. | FuriousGold | 0 | 08-02-2007 20:08 |
