05-13-2007, 21:40 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Madrid, ES. Age: 41
Member: 51153 Status: Offline Sonork: 100.113241 Thanks Meter: 3,682 | Griffin team can u repair this problem or no? pleas help.dont say use search,i was read all thread. tell me what procedure to start and to fix this problem. thank you best team. i like MT-box all platforme |
05-14-2007, 11:15 | #3 (permalink) |
No Life Poster Join Date: Jul 1999 Location: Netherlands Age: 57
Member: 334 Status: Offline Thanks Meter: 120 | Please give more info about this phone so we can help you. Did you do a selftest with the phone ?Check imei or simlock data,and was the phone working before you flashed it? |
05-14-2007, 11:43 | #4 (permalink) |
Member: 51153 Status: Offline Sonork: 100.113241 Thanks Meter: 3,682 | yes i do self test,also imei now is ok after write RPL but always after flash,phone is contact retailer. before this phone come in my shop with imei 123456107899? |
05-14-2007, 22:02 | #5 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: singapore Age: 55
Member: 173565 Status: Offline Thanks Meter: 71 | Quote:
then use it ,you have the RF and Energy settings in eeprom corrupted . | |
05-15-2007, 05:00 | #6 (permalink) |
Registered User Join Date: Apr 2005 Age: 42
Member: 133028 Status: Offline Thanks Meter: 5 | yes i got same pro too Phone is in: Unknown mode Model: RM-36 ( RM-36) V 04wk47_m_v14.2.1/09-11-06/RM-36 (c) Noki Production serial number Product code Module code Basic production code Flash code Order number Long production SN MCU SW V 04wk47_m_v14.2.1/09-11-06/RM-36/(c) Noki PCI RFIC 150a160e DSP pb04w47v23 LCD 2721820 APE SW Core V 5.04.40/20-11-06/RM-36/(c) NOKIA. APE Variant V 5.04.40-Thai/28-11-06/RM-36/(c)NOKIA Retu 32 Tahvo 52 APE HW 256 APE ADSP SW 52041 Camera 3 IMEI: 358358008701492 WARNING: VPP pin is not connected, disabling VPP. PMM Send File Warning: Failed to write 001:0000, 114bytes. Use SX4 button to authorize Warning: Failed to write 001:0001, 4bytes. Use SX4 button to authorize Warning: Failed to write 001:0002, 86bytes. Use SX4 button to authorize Warning: Failed to write 001:0004, 110bytes. Use SX4 button to authorize Warning: Failed to write 001:0005, 4bytes. Use SX4 button to authorize Warning: Failed to write 001:0006, 86bytes. Use SX4 button to authorize Warning: Failed to write 001:0008, 110bytes. Use SX4 button to authorize Warning: Failed to write 001:000D, 86bytes. Use SX4 button to authorize Warning: Failed to write 001:000F, 4bytes. Use SX4 button to authorize Warning: Failed to write 001:0010, 86bytes. Use SX4 button to authorize Warning: Failed to write 001:0012, 86bytes. Use SX4 button to authorize Warning: Failed to write 001:0014, 86bytes. Use SX4 button to authorize Warning: Failed to write 001:0018, 84bytes. Use SX4 button to authorize Warning: Failed to write 001:0019, 16bytes. Use SX4 button to authorize Warning: Failed to write 135:0000, 4bytes. Use SX4 button to authorize Warning: Failed to write 135:0001, 2bytes. Use SX4 button to authorize Warning: Failed to write 135:0002, 12bytes. Use SX4 button to authorize Warning: Failed to write 135:0004, 12bytes. Use SX4 button to authorize Warning: Failed to write 135:0005, 12bytes. Use SX4 button to authorize Warning: Failed to write 135:0007, 12bytes. Use SX4 button to authorize Warning: Failed to write 135:0008, 12bytes. Use SX4 button to authorize Warning: Failed to write 135:0011, 12bytes. Use SX4 button to authorize Operation Completed Phone is in: Unknown mode Imei: 358358008701492 SIM Unlock FAILED Failed to locate SX4 on PC. Connecting server Connect... Login... IMEI: 358358008701492 busy, waiting... Connect... Login... busy, waiting... PMM Authorize SUCCESSFULL |
Does please anyone knows if Griffin Team can help me on this ??? | eskerra | MT-BOX | 2 | 03-16-2010 09:54 |
Can i repair this problem on nokia N95-8gb only with UFS and how? | Boshko_Alfa | Nokia Base Band 5 ( BB-5 ) | 0 | 07-21-2009 10:05 |
griffin team,can i repair this phone bt rpl or no | F@RUK S | MT-BOX | 7 | 05-10-2007 14:25 |
pleas help can i repair this phone by rpl or no | F@RUK S | MT-BOX | 1 | 05-10-2007 09:49 |
