05-10-2007, 00:27 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: On Earth
Member: 266339 Status: Offline Thanks Meter: 99 | Help pls!have a look Can someone pls interprete me those instructions? MTBOX:XXXXXXXXXX - Nokia Flash/Repair v1.29.5 Box: CR V 1.002 256 Code: NK V 1.001 1044 SN: XXXXXXXXXX Nokia Unlimited: 58 times started SonyEricsson Trial: 10 left, each max 15min ============= Set Flash mode for info ============= VBat is 3.95V Vpp pin has 0.55V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Boot... Invalid response from RAP3 boot( cable problem/damaged RAP3 chip/damaged phone power circuit ============= Set FBus mode for info ============= VBat is 3.91V Vpp pin has 0.56V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode Model: RM-189 ( RM-189) V 3.21/20-07-06/RM-189 (c) NMP IMEI: XXXXXXXX BR |
05-10-2007, 10:34 | #3 (permalink) |
Member: 266339 Status: Offline Thanks Meter: 99 | i use nokia 6060(for 1600,2600,2310,2610).I have two differents ones. One with and one without that kind of small plier(i think it is called crocodile adaptor or ....). After set and done,the one with that plier works.Only i must try many times b4 phone get connected.Can u advice me a particular kind of cable that what one hand? BEST REGARDS TO THE WHOLE GRIFFIN TEAM FOR THIS WONDERFULL BOX. I get my 1st nokia 2310 unlocked. Great!!!!!!!!!!!!!!!!!!!!!!! |
05-10-2007, 14:56 | #4 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | YOU DONT NEED TO HAVE A ANY CROCODILE. you need to have a 2 resistors inside of cable 1st series in BSI line need to be 3.3k for dct4 phones and 5.1k for BB5 and another is between BSI and GND an he is 68k |
pls have a look | lakshmireddy | Cruiser Suite | 2 | 10-27-2009 04:43 |
Please help to have a look at that R9G007 to have the simplified Chinese? | shumrtong | Sony Ericsson | 0 | 12-25-2007 03:57 |
w200i!! Have a look pls!! | benarmand | MT-BOX | 2 | 12-19-2007 09:57 |
HTTP://GSM.VN/GDS pls have a look ! | GSMVN | GSM Mobile Links | 1 | 11-28-2006 19:07 |
