05-16-2007, 15:45 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: EGYPT Age: 47
Member: 217479 Status: Offline Thanks Meter: 267 | How to be safe in .ask to .rpl with BB5 ??? Please help about that, thnx in advance, B.R ... |
05-16-2007, 16:31 | #2 (permalink) |
No Life Poster Join Date: Nov 2005 Location: MoNiToR
Member: 199405 Status: Offline Sonork: 100.1576571 Thanks Meter: 322 | mate in ask file who u send 2 the server 2 make convert 2 rpl file the server always first read the data in this file before make convert inside file some data about serial if this data not like as the file sn.... it wont make rpl thats all info i know about this br |
05-16-2007, 17:03 | #3 (permalink) |
Member: 217479 Status: Offline Thanks Meter: 267 | mohA, thnx for trying help but you missed something; may be the IMEI on RAP3G itself has turned corrupted not the IMEI on flash IC in that case the .ask file is holding another IMEI than the true IMEI upon that the generated .rpl file will be also not the one we need as it happens in DCT4 & WD2 if we hadn't cared about compare the UEM IMEI & the IMEI that have been read by a griffin box, i hope you get it, & still waiting for a terminated answer about is there a chance to know the RAP3G's IMEI when the set's IMEI fet corrupted or not, & if the answer is not then we have to request from griffin team to recover this issue soon ... |
05-16-2007, 17:42 | #4 (permalink) |
Member: 199405 Status: Offline Sonork: 100.1576571 Thanks Meter: 322 | i mean thats all data inside the ask file must be not conflect if ur serial is wrong...they will know that cause it will make some conflect with the other data so,,,rpl cant convert |
05-16-2007, 17:55 | #5 (permalink) |
Member: 217479 Status: Offline Thanks Meter: 267 | No, it can happen with DCT4 & WD2 & already happened with me before when i missed to compare the two IMEI for example the true IMEI was 35539600046030 & the .ask file IMEI was 35534700046030 & with that case the set get back working without rejecting SIM card but shuts down after 30 second & sure it's UEM faulty, so do you think it can't happen with BB5 ? well, about me i'm sure it can happen ... |
05-17-2007, 09:43 | #6 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | yes this problem is - in uem IMEI is different with this in flash IC. about this have e many reson may be phone mistake when power off nd write some trash data in flash. when you calculate RPL with imei in UEM all be ok.2 imeis will be same and phone will work good |
how can red ask and rpl with mt-box? | daimobile08 | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 08-20-2008 22:37 |
How to get the DCT4 ASk to RPL service in UB? | nishaon | Universalbox | 10 | 11-04-2007 21:12 |
would you like to have a software ask to rpl converter??? | oculesics | GSM Programming & Reverse Engineering | 16 | 06-24-2007 17:38 |
