03-08-2007, 13:07 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Location: in the heart of africa
Member: 59796 Status: Offline Thanks Meter: 0 | MT BOX Adapter Not Used My Nokia N70 was not powering up,so i connect the N70 direct to box without adapter, is box now damaged? so easy? i tried to check if pin 1 & 10 level but it looks fine,but how can i confirm? because i need to know 100% my is perfect. If this is damaged so easy because i connect n70 cable direct,then can box be fixed? some1 please help,i have a few teething problems with mt box,as i am learning this new box,i knew old griffin but now it is little hesistant for me because new box please help |
03-08-2007, 13:27 | #2 (permalink) |
Freak Poster Join Date: Jan 2007
Member: 436006 Status: Offline Thanks Meter: 73 | the only thing you can damage with a 8 pin cable connected directly to mt-box is just the RJ48 socket,, just check again for the pin 1 and pin 10,,, all should be ok also maybe ur adapter is damaged |
03-08-2007, 13:37 | #3 (permalink) |
Member: 59796 Status: Offline Thanks Meter: 0 | i wrote pm to 6230 using the adapter before itried n70 & it worked,so hopefully not damaged but if damaged how do i fix? & who can replace socket? |
03-09-2007, 11:19 | #5 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | for me not have a problem with box or phone or adapter. just restart pc ,box and aways conect bb5 phones to box after you open exe!!!!!! mesure resistance between + and - on the phone battery connector!!!!! |
03-09-2007, 11:28 | #6 (permalink) | |
No Life Poster Join Date: Apr 2004 Location: Milano, Italy Age: 38
Member: 62336 Status: Offline Thanks Meter: 115 | Quote:
About your problem with the n70 cable, maybe you need to modifiy it. With Best Regards Bypx | |
mt box adapter not light and box problam | odayking | MT-BOX | 8 | 12-11-2007 18:03 |
Need Mt-box adaptator schematic !! | Gsmtechno | MT-BOX | 30 | 09-03-2007 09:27 |
MT-Box "freeze" when use update tool?!?! | KelvinShadow | MT-BOX | 2 | 12-18-2006 14:25 |
mt-box/pkd-1 use!!!!!! | andrew14 | MT-BOX | 10 | 11-09-2006 16:00 |
heat in the mt-box adapter | bandiras002 | MT-BOX | 9 | 03-26-2006 09:54 |
