08-22-2007, 15:02 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Salvador - Bahia - Brazil Age: 48
Member: 172567 Status: Offline Thanks Meter: 90 | MT box/ MT Box Pro versus 6125 V4,20 |
08-22-2007, 17:03 | #3 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | 1st. ver 4.20 now is unlockable: W 04.20/13-11-06/RM-178/(c) Nokia. Auto backup SIMLOCK... ================================= bb5bckup\358844009791780.pm nBackup file already exists! SKIPPING backup ================================= Using Account: **** Connect... Resp: o/0110/hello there Login... OK, available count 129; busy, waiting... Server Response OK. =================================== Connect TPs V 04.20/13-11-06/RM-178 (c) Nokia. IMEI: 358844009791780 Counters 5/10, 0/3 V 04.20/13-11-06/RM-178 (c) Nokia. IMEI: 358844009791780 Counters 5/10, 0/3 TPs OK UNLOCK SUCCESSFULL SUCCESSFULL V 04.20/13-11-06/RM-178 (c) Nokia. IMEI: 358844009791780 Operator: 0000000000000000 Profile bits: 2440700000000000 Sim Status: Not locked 2nd. Phone CAN be downgraded!!!! WARNING: THE VERSION YOU SELECTED: 03.72 is NOT the highest installed!!! the highest available is: 04.20 BB5 Downgrade - - - - - - - - - - - VBat is 3.96V Vpp pin has 1.36V, Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Test mode Found record. Clearing and sending to phone.. ============== Staring flash procedure ================= BB5 PM back Phone is in: Test mode IMEI: 358844009791780 Backup file: C:\Program Files\GriffinTeam\MT-Box\nokia\bb5bckup\RM-178_358844009791780.pm Processing File: rm178b503.720.mcusw.bin Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Backup: \GSM_35884400979178_0.r3c Erase RAP3 [00000000 - 000DFFFF] Erase RAP3 [00100000 - 0123FFFF] Erase[18.13 MB]... Waiting response for 320 Sec...in 88.17s Flash[12.99 MB]...in 27.47s * * Processed file in 127.39 seconds Processing File: rm178b503.72.image_e Content area page size is 64K. Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [01260000 - 01FDFFFF] Erase[13.50 MB]... Waiting response for 320 Sec...in 44.88s Flash[4.38 MB]...in 9.28s * * Processed file in 66.77 seconds Extract content...OK Processing File: rm178b503.72.ppm_e Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [00DE0000 - 0123FFFF] Erase[4.38 MB]... Waiting response for 320 Sec...in 0.88s Flash[3.03 MB]...in 6.44s * * Processed file in 16.30 seconds * * * Phone flashing done in 3:59 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... V 03.72/10-08-06/RM-178 (c) Nokia. IMEI: 358844009791780 Factory Default Settings...OK |
08-31-2007, 18:45 | #6 (permalink) |
Cheater -Don't Deal with him- Join Date: Oct 2004 Age: 45
Member: 85712 Status: Offline Thanks Meter: 131 | 6125 V4.20 Error how solved this? Phone is in: Test mode Model: RM-178 (Cougar ) V 04.20/13-11-06/RM-178 (c) Nokia. Production serial number GDE746035 Product code 0535024 Module code Basic production code 0529960 Flash code Order number Long production SN MCU SW V 04.20/13-11-06/RM-178/(c) Nokia. HW 0401 PCI RFIC 17211721 DSP pb05w46v43.1 PPM V 04.20/15-11-06/RM-178/(c) Nokia. /I Retu 32 Tahvo 53 IMEI: 354802012947207 WARNING: VPP pin is not connected, disabling VPP. Phone is in: Test mode Imei: 354802012947207 !!!!!!BOX ERROR!!!!! Check connector. |
09-02-2007, 06:34 | #7 (permalink) |
Member: 409197 Status: Offline Thanks Meter: 75 | this can be solved when read this forum clean good connectors between box and MT-PRO adapter, RJ-45 on a MT-BOX have bad 1,10 pins. after clean pres good connection between 2 boxes and try all be ok . i don't see this question from long time, may be you are new in this !!!! Please next time first use search button on the forum and then post new thread. About this problem have a over 200 threads with the same answer |
09-03-2007, 12:49 | #8 (permalink) | |
Member: 85712 Status: Offline Thanks Meter: 131 | Quote:
I am using MT BOX PRO , cable DKu-2 RJ45. Need make unlock, how solved ? | |
09-03-2007, 20:35 | #10 (permalink) | |
No Life Poster Join Date: Aug 2002 Location: Romania Buzau Age: 54
Member: 14468 Status: Offline Thanks Meter: 50 | Quote:
best regards vali | |
09-04-2007, 05:08 | #11 (permalink) | |
Insane Poster Join Date: Sep 2005 Location: Brazil-Bahia-Salvador Age: 49
Member: 179003 Status: Offline Thanks Meter: 8 | Quote:
09-17-2007, 19:42 | #12 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 47
Member: 77446 Status: Offline Thanks Meter: 8 | Hello, I´m trying to downgrade a 6125 but always get the following log (the phone doesn´t power on after this). Phone is in: Local mode Model: RM-178 (Cougar ) V 04.20/13-11-06/RM-178 (c) Nokia. Production serial number GDE409540 Product code 0535024 Module code Basic production code 0529960 Flash code Order number Long production SN MCU SW V 04.20/13-11-06/RM-178/(c) Nokia. HW 0401 PCI RFIC 17211721 DSP pb05w46v43.1 PPM V 04.20/15-11-06/RM-178/(c) Nokia. /I Retu 32 Tahvo 53 Content Pack Content: cv_brazil/V 04.20/13-11-06/RM-178/(c) Nokia. / IMEI: 354802010996*** Downloaded news update from GriffinTeam. Switching to Online news tab BB5 Downgrade - - - - - - - - - - - VBat is 3.89V Vpp pin has 1.34V, Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode Found record. Clearing and sending to phone.. ============== Staring flash procedure ================= Processing File: rm178b503.720.mcusw.bin Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [00000000 - 000DFFFF] Erase RAP3 [00100000 - 0123FFFF] Erase[18.13 MB]... Waiting response for 320 Sec...in 39.00s Flash[12.99 MB]...in 37.42s * * Processed file in 86.31 seconds Processing File: rm178b503.72.image_i Low level format...fail Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [01260000 - 01FDFFFF] Erase[13.50 MB]... Waiting response for 320 Sec...in 21.44s Flash[4.51 MB]...in 13.33s * * Processed file in 97.06 seconds Extract content...fail Processing File: rm178b503.72.ppm_i Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [00DE0000 - 0123FFFF] Erase[4.38 MB]... Waiting response for 320 Sec...in 1.00s Flash[2.47 MB]...in 7.34s * * Processed file in 18.13 seconds * * * Phone flashing done in 4:44 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! What´s wrong??? BR |
09-18-2007, 11:22 | #13 (permalink) |
Member: 409197 Status: Offline Thanks Meter: 75 | use 1.37.exe -- all is ok this is the log: Phone is in: Test mode Scanning files, please wait... Done WARNING: THE VERSION YOU SELECTED: 04.20 is NOT the highest installed!!! the highest available is: 05.43 Model: RM-178 ( 6125) V 04.20/13-11-06/RM-178 (c) Nokia. Production serial number CME420649 Product code 0531573 Module code Basic production code 0529960 Flash code Order number Long production SN MCU SW V 04.20/13-11-06/RM-178/(c) Nokia. HW 0400 PCI RFIC 17211721 DSP pb05w46v43.1 PPM V 04.20/15-11-06/RM-178/(c) Nokia. /K Retu 32 Tahvo 53 Content Pack Content: k/V 04.20/13-11-06/RM-178/(c) Nokia. IMEI: 358844009791780 WARNING: THE VERSION YOU SELECTED: 03.72 is NOT the highest installed!!! the highest available is: 05.43 BB5 Downgrade - - - - - - - - - - - Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Test mode Found record. Clearing and sending to phone.. ============== Staring flash procedure ================= BB5 PM back Phone is in: Test mode IMEI: 358844009791780 Backup file: C:\Program Files\GriffinTeam\MT-Box\nokia\bb5bckup\RM-178_358844009791780.pm Processing File: rm178b503.720.mcusw.bin Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Backup: \GSM_35884400979178_1.r3c Erase RAP3 [00000000 - 000DFFFF] Erase RAP3 [00100000 - 0123FFFF] Erase[18.13 MB]... Waiting response for 320 Sec...in 88.69s Flash[12.99 MB]...in 27.45s * * Processed file in 128.52 seconds Processing File: rm178b503.72.image_k Low level format...OK Content area page size is 64K. Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [01260000 - 01FDFFFF] Erase[13.50 MB]... Waiting response for 320 Sec...in 72.27s Flash[4.25 MB]...in 9.03s * * Processed file in 96.06 seconds Extract content...OK Processing File: rm178b503.72.ppm_k Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [00DE0000 - 0123FFFF] Erase[4.38 MB]... Waiting response for 320 Sec...in 0.86s Flash[3.01 MB]...in 6.39s * * Processed file in 16.30 seconds * * * Phone flashing done in 4:29 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... V 03.72/10-08-06/RM-178 (c) Nokia. IMEI: 358844009791780 Factory Default Settings...OK |
09-18-2007, 19:10 | #14 (permalink) |
Member: 77446 Status: Offline Thanks Meter: 8 | Hello, I´m getting the same thing with 1.37exe. As you can see, software fails in low level formating and in the end. What is wrong? I am using cable with 5 pins and UseTXline option unchecked. Lowlevel format before content option is also checked. Could you please, help me? See the log with 1.37exe below: Phone is in: Local mode Model: RM-178 (Cougar ) V 04.20/13-11-06/RM-178 (c) Nokia. Production serial number GDE409540 Product code 0535024 Module code Basic production code 0529960 Flash code Order number Long production SN MCU SW V 04.20/13-11-06/RM-178/(c) Nokia. HW 0401 PCI RFIC 17211721 DSP pb05w46v43.1 PPM V 04.20/15-11-06/RM-178/(c) Nokia. /I Retu 32 Tahvo 53 Content Pack Content: cv_brazil/V 04.20/13-11-06/RM-178/(c) Nokia. / IMEI: 354802010996*** BB5 Downgrade - - - - - - - - - - - VBat is 3.88V Vpp pin has 1.32V, Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode Found record. Clearing and sending to phone.. ============== Staring flash procedure ================= Processing File: rm178b503.720.mcusw.bin Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [00000000 - 000DFFFF] Erase RAP3 [00100000 - 0123FFFF] Erase[18.13 MB]... Waiting response for 320 Sec...in 39.23s Flash[12.99 MB]...in 37.16s * * Processed file in 86.83 seconds Processing File: rm178b503.72.image_i Low level format...fail Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [01260000 - 01FDFFFF] Erase[13.50 MB]... Waiting response for 320 Sec...in 20.44s Flash[4.51 MB]...in 13.20s * * Processed file in 96.00 seconds Extract content...fail Processing File: rm178b503.72.ppm_i Boot... rap3gv3_2nd.fg RAP3Gv3_algo.fg Erase RAP3 [00DE0000 - 0123FFFF] Erase[4.38 MB]... Waiting response for 320 Sec...in 1.02s Flash[2.47 MB]...in 7.27s * * Processed file in 18.09 seconds * * * Phone flashing done in 4:43 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! |
6125 RM-178 v4.20 successfully unlocked with UID box | abyssx | UID - Box | 0 | 12-26-2007 00:33 |
Need solution for 6125 v4.20. | kurt_cobain | UID - Box | 0 | 10-30-2007 15:20 |
Problems trying to unlock nokia 6125 v4.20 | Racionais | BB5BOX | 0 | 10-27-2007 17:27 |
NK 6125 RM-178 V4.20 -- Unlock Fail | ligteltelecom | BB5BOX | 14 | 10-24-2007 23:15 |
6125 v4.20 to v3.72???? | kurt_cobain | UID - Box | 1 | 10-05-2007 16:54 |
