12-11-2008, 08:15 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: New Zealand
Member: 612635 Status: Offline Thanks Meter: 194 | MT Box & Nokia 6680 problem I found the ADA-019 MT-BOX Adapter and am trying to unlock the Nokia 6680 - I take out the battery and then connect the AT112 cable (6680) to the phone. Plug the phone into the the adapter + box - Open the software (Nokia flash/repair v1.55) - Select the phone and click Phone Info - But the computer says Phone is in: Phone is not responding, power on phone. But the phone wont turn on when plugged thur the adapter (It does however go into local mode when i plug the phone directly into the MT-Box) Can anyone please help?? Thanks |
12-19-2008, 11:23 | #3 (permalink) |
Member: 612635 Status: Offline Thanks Meter: 194 | Hi there Have attached the CA-70 usb cable to the Nokia 6680, opened v1.55, switched on the phone but get the same message "Phone is in, Phone is not responding, please power on phone" Please help |
12-19-2008, 13:14 | #4 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Islamic Republic Age: 36
Member: 466635 Status: Offline Sonork: 100.1614186 Thanks Meter: 482 | Forset u check your cable your cable is 5 pin our 7 pin 7 pin and 5 pin recaured adapter and 10 no need adapter u enter direct cable in mt-box 1st time u attch the cable phon and box not showing local mode u remove the cable from box and reattch and then it's showing local mode our test mode please check and then post result b.r sherry mobiles |
12-21-2008, 13:58 | #5 (permalink) |
Member: 612635 Status: Offline Thanks Meter: 194 | I pressed OK and get the following Phone is in: Phone is not responding, power on phone! ============= Set Flash mode for info ============= VBat is 3.94V Vpp pin has 0.10V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 0, Bsi 0 Boot... Using Tx2 Data line. Invalid response from RAP3 boot( cable problem/damaged RAP3 chip/damaged phone power circuit ============= Set FBus mode for info ============= VBat is 3.96V Vpp pin has 0.09V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 0, Bsi 0 |
MT Box & MT Lite For Sale | shahzaadbutt | Sell ur Old and Used Stuff | 6 | 03-27-2008 16:52 |
mt-box & nokia phone | king_of_rajasthan | MT-BOX | 0 | 12-21-2007 15:51 |
SE CID52 Unlocking Solution, MT Lite, MT Box & More. | Networkunlock | Main Sales Section | 0 | 11-05-2007 12:32 |
FS: Sony Ericsson K750i Unlocked & Nokia 6680 | anne_casablanca | Sell ur Old and Used Stuff | 0 | 04-27-2006 08:26 |
Mt-box V 1.11 Problem Whit 6680 | micione | MT-BOX | 1 | 11-16-2005 15:04 |
