07-03-2007, 18:35 | #1 (permalink) |
Freak Poster Join Date: Feb 2002 Location: BG
Member: 9216 Status: Offline Thanks Meter: 21 | MT-Pro: about problem unlock 5200 v3.92 and 6300 v4.71 if you get this many times and phone not unlocked and phone have inside spansion flash or "sec 64 ... " try this: Add in griffin.ini in [interface_options] revision=D This is ONLY for 5200 ONLY for 3.92 version and 6300 v4.71. when finishig with this phone you MUST REMOVE THIS OPTION FROM griffin.ini V 03.92/13-10-06/RM-174 (c) Nokia. IMEI: 355xxxxxxxx TPs OK TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED FAILED, ALL ATTEMPTS USED! Sending SIMLOCK record... Last edited by SoftMobile; 07-11-2007 at 14:04. |
07-03-2007, 20:24 | #3 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Hong Kong
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Go to C:\Program Files\GriffinTeam\MT-Box\ There will find Griffin.ini file Open it in any text editor and edit. Griffin.ini before edit: [interface_options] extras=1 extras_index=1 RPL_208=0 LogToFile=1 FlsaDisplayDetail=0 ProductProfile=1 GprsSettings=1 NvdAccess=1 AutoUnlock=0 UpdateProductCode=0 ResetUserCode=0 NvdNvd=1 SkipBluetooth=0 FactoryDefaultSettings=1 Griffin.ini after edit: [interface_options] revision=D extras=1 extras_index=1 RPL_208=0 LogToFile=1 FlsaDisplayDetail=0 ProductProfile=1 GprsSettings=1 NvdAccess=1 AutoUnlock=0 UpdateProductCode=0 ResetUserCode=0 NvdNvd=1 SkipBluetooth=0 FactoryDefaultSettings=1 save file and start MTB NK software 1.33 When you finish with this phone back Griffin.ini to previous state or you can simply rename it and save for next time |
07-04-2007, 16:28 | #12 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Spain Age: 45
Member: 16165 Status: Offline Thanks Meter: 10 | No... look, i will explaine exactly whats happend: V3.92 working if the type of hardware of PCB is: 2001. If is 2002 or 2003, u must to directly update sw to 4.71!!! PCB hardware 2001 have a type of flash and the others have other... ! So simple!!! All oK now? |
07-05-2007, 17:27 | #15 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 54
Member: 109301 Status: Offline Thanks Meter: 0 | Thanks br, this is too good to be true an info. But is it possible to upload 4.71 here for me to download? since site is currently under construction. You have really made my day. br..... |
6300 v4.71 spansion sucessful unlock but phone has no network | brandon | BB5BOX | 1 | 03-09-2008 14:18 |
can not unlock 6300 v4.71 SEC 740 SF75 | div_raj | J.A.F. V-SPEC | 1 | 01-23-2008 13:23 |
6300 v4.71 sec atb unlock supported ??? | dannyogolo | BB5BOX | 3 | 10-04-2007 13:32 |
6300 v4.71 Needed!!! | TheBrain | Nokia Base Band 5 ( BB-5 ) | 4 | 05-17-2007 11:41 |
