06-26-2007, 20:52 | #1 (permalink) |
No Life Poster Join Date: May 2004 Location: the past, which is your future Age: 45
Member: 65216 Status: Offline Thanks Meter: 23 | mt pro eats logs and no unlock, be aware. could u please help me? i have at least 3 nok 6131 (v5.50) that after tp ok, unlock cant be done and log is counted. when i try to restore pm backup, process cantbe done after millions of tries. here is log could you please restore my logs? thanks here is 1 sample: Phone is in: Test mode Imei: 35480601xxxx30 W 06.10/16-02-07/RM-115/(c) Nokia. Auto backup SIMLOCK... ================================= bb5bckup\354806012033330.pm nBackup file already exists! SKIPPING backup ================================= =================================== V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 3548060xxxxxx30 Operator: 0000000000000000 Profile bits: 7223100000000000 Closed on Mcc Mnc: 722310 Closed on Mcc Mnc: 74810F Closed on Mcc Mnc: 74402F Closed on GID1: 722310 Closed on GID1: 74810F Closed on GID1: 74402F =================================== Using Account: mexxxxbb5 Connect... Resp: o/0110/hello there Login... OK, available count 240; busy, waiting... Server Response OK. =================================== Connect TPs V 06.10/16-02-07/RM-115 (c) Nokia. IMEI: 35480601xxxx330 TPs OK TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED FAILED, ALL ATTEMPTS USED! Restarting phone Finished Restarting phone box error !!!!!!BOX ERROR!!!!! |
06-26-2007, 22:51 | #3 (permalink) |
Member: 65216 Status: Offline Thanks Meter: 23 | i read all the 6131 faq, but posted sollution does not help nor work . when trying to write pm backup, using sx4 auth. always 401 error, i have 1 mb dsl service and tryied 100x times during 3 days. im using shortened tp adapter, mt<>mtpro conection is good, phones has 5.50 version after downgrade, so what is solution? |
07-28-2007, 19:12 | #7 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 54
Member: 109301 Status: Offline Thanks Meter: 0 | TPs OK TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED FAILED, ALL ATTEMPTS USED! This means you first have to do ask-rpl to return fon to 0/10. The log you showed means your fon is v06.10 Now select v5.50 flash files and press downgrade. After read fon and make sure it is v5.50 then try unlock again. |
07-28-2007, 20:50 | #8 (permalink) |
Freak Poster Join Date: Jan 2004 Age: 42
Member: 49044 Status: Offline Thanks Meter: 8 | i am always upgrading 6.10 then downgrade 5.50 then 6.10 at have no problem at all. if you have 0/10 and pm wont help check if your software can read pm proper on one pc i have all pm backups only 8b ... so its good to make pm and crt backup on other tools to be on safe side |
07-30-2007, 10:20 | #9 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | use 1.35 and don remove TP after TPs OK TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED TESTPOINT FAILED FAILED, ALL ATTEMPTS USED! |
iPhone OS 3.1 and iTunes 9 now available, unlockers be aware | srkhan | iPhone 2 / iPhone 3G / iPhone 3GS | 4 | 09-11-2009 03:08 |
Fs: Mt Box + Mt Pro 245 Logs | yeldar | Sell ur Old and Used Stuff | 0 | 09-07-2007 18:03 |
server eat logs and not unlock phone :-( | foony | MT-BOX | 4 | 07-26-2007 10:57 |
Griffin Server just eats logs and doesn't unlock phones!!!! | byteforce | Griffin | 8 | 03-25-2005 17:51 |
