N95 dead after flashing with usb,I have griffin cable... I flash my phone with phoenix via usb cable,and is dead only Nokia logo.I have griffin cable but I have this error: Scanning files, please wait... Done Selected Highest installed version: 10.0.018 Using Tx2 Data line. Processing File: RM-159_10.0.018_PR.C0R Boot... RAPIDOv102_2nd.fg RAPIDOv11_algo.fg omap2420_m1_2nd.fg RAPIDOv102_2nd.fg RAPIDOv11_algo.fg omap2420_m1_2nd.fg %%%%%%%% ERROR BOOTING: What it's wrong? |
hi modify your FBUS cable & use to flash phone. |
how modify ? change rj45 on rj 48 and add pins ? or add some pins ? |
This thing for N95 is anoying a lot people,i've 2 cables 1 with tx2 line and without,no one is working for N95,but i connect the cables to twister and the enters in test mode,but mt-box dont do nothing. Both cables are modified. |
for flashing n95 you need to have a TX2. find shematic in forum and modify your cable then you have a BOOT OK |
I have the schematic and i've checked my cable and everithing looks ok,i dont find any error in connections. |
then your rj-48 on a box is brocken may be. click on 6th buton and send the log |
yes log is better ot help you out best of luck & Best Regards GSMCrazy1 |
This is what i get: Pins: Mbus 1, Box Tx 1, Box Rx 0, Bsi 0 Boot... Using Tx2 Data line. Invalid response from RAP3 boot( cable problem/damaged RAP3 chip/damaged phone power circuit ============= Set FBus mode for info ============= Pins: Mbus 1, Box Tx 1, Box Rx 0, Bsi 0 What can the problem be.When i connect cable to twister i've done factory defaults without any problem.I'm only having problem for flasing this phone,all other N series or E series without any problem,of course for other cables i use adaptor,this one i connect directly. |
Sorry this is log when i use cable without tx line+adaptor ============= Set Flash mode for info ============= Pins: Mbus 1, Box Tx 1, Box Rx 0, Bsi 0 Boot... RAPIDOv102_2nd.fg RAPIDOv11_algo.fg omap2420_m1_2nd.fg Failed to boot send APE 2ND (bad APE) Phone Type: BB5 ------------------- SYSTEM ID Response: 11 blocks ------------- SYSTEM_ASIC_ID( APE ): 24200705 ASIC_MODE_ID( APE ): 00 PUBLIC_ID( APE ): A7F04A5753EA280915EA6178D6467F23F94B11A1 ROOT_KEY_HASH( APE ): BA8710A7E1CD5A2909B9A875DB27AA2400000000 SYSTEM_ASIC_ID( RAP ): 000000010000022600010006400C192101011103 EM_ASIC_ID( RAP ): 00000295 EM_ASIC_ID( RAP ): 00000B21 PUBLIC_ID( RAP ): 0D900001CE4400580F39C32B9A2DC9F3F4C0A8B6 ASIC_MODE_ID( RAP ): 00 ROOT_KEY_HASH( RAP ): CAEEBB65D3C48E6DC73B49DC5063A2EE ROM_ID( RAP ): F2C6EBADC86E6189 --------------- Device ID Response: 3 blocks ------------- Storage Device: Owner Asic: RAP Type: NOR Flash Index: 0 Flash: Amd, 0001 0035 0000 6921 Storage Device Contents: Owner Asic: RAP 000000000000000000000000000000000000 ============= Set FBus mode for info ============= Pins: Mbus 1, Box Tx 1, Box Rx 0, Bsi 0 |
i had the same problem but with N93 this is what i did: 1-flash only MCU 2-reconnect box 3-flash only PPM phone revive again just try this solution you have no think 2 lose ! |
so, there're 2 options: - make/modify cable become rj48/10 pins cable. - modify mt-box 10 to 8 adapter, use 7th pin in rj45 (between vbat & bsi) to make tx2 line, connect to rx2 in phone. regards |
i want to know hot modfy the cable 10 pin to work with 8 pin please i want more details |
need to open adapter and solder wire to grey wire. this cable is TX2 line. on a cable for phone need put one more pin for a tx2 line and solder wire,then connect 2 wires |
can you explain to me with drawing a picture hot to mdify my adapter please |
