03-06-2006, 18:40 | #1 (permalink) |
Freak Poster Join Date: Feb 2005 Location: Jerez de la Frontera , Cadiz , SPAIN Age: 48
Member: 115106 Status: Offline Thanks Meter: 4 | Newbie :( I donīt know how to conect my MT-box , Phone is in: Phone is not responding After I install everything ...... as user manual guide , I try to conect N70 , 8800 and 6111 , but always said : Phone is in: Phone is not responding, power on phone! I try to turn on , but also can NOT turn on by pressing power Please give an advice if I did something wrong Thank you ..... BR Carlos |
03-06-2006, 18:52 | #3 (permalink) |
Member: 115106 Status: Offline Thanks Meter: 4 | Thank you .........for your responce 1 - I conect adapter to box 2 - I conect usb to box 3 - I conect N70 cable to adapter 4 - I conect cable to N70 5 - I press phone info 6 - Green ligth is con and red ligth is blinking 7 - Phone is in: Phone is not responding, power on phone! 8 - I try to power the phone , nothing happens Thank you Br CArlos |
03-06-2006, 19:14 | #4 (permalink) | |
No Life Poster Join Date: Dec 2002 Age: 47
Member: 18855 Status: Offline Thanks Meter: 1,938 | when u conect the cable did you see test mode ?or local mode ? if no then try power on your phone and tehn click phone info Quote:
03-06-2006, 19:33 | #5 (permalink) |
Member: 115106 Status: Offline Thanks Meter: 4 | Thank you .........for your fast responce when I turn on and open software , the red ligth is on No test mode No local mode , it there I only see Unknow ...... I press the botton to turn on , nothing happens .......... after I press read info ...... always is the same ¨I try to power the phone , nothing happens¨ I try to pass Local , test and Normal mode and do same procedure , Also same ¨I try to power the phone , nothing happens ¨ Thank you BR Carlos |
03-06-2006, 20:09 | #6 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Hong Kong
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Close software Disconnect box from USB Disconnect phone from cable Connect box to USB Update box using MT box tool v3.4 Start MTB NK 1.17 Connect phone to cable Wait to see Lcal Mode on phone LCD Press Phone info button |
03-06-2006, 20:18 | #7 (permalink) |
Member: 115106 Status: Offline Thanks Meter: 4 | thank you for answer .... I do the procedure , If I wait automatic local model , I have wait more than 2 minute , nothing happens If I try ............. manual switch to local mode and press phone info .......... Phone is in: Phone is not responding, power on phone! Thank you BR Carlos |
03-06-2006, 20:25 | #8 (permalink) |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Can you check phone adapter it is ok |
03-06-2006, 20:32 | #9 (permalink) |
Member: 115106 Status: Offline Thanks Meter: 4 | Thank for your help Yes , itīs ok Also this box came from I-phone ....... I have to said red ligth is always on until I press phone info , after green ligth is on and red one is blinking . Also I try this : ============= Set Flash mode for info ============= Pins: Mbus 0, Box Tx 1, Box Rx 0, Bsi 0 Boot... ============= Set FBus mode for info ============= Pins: Mbus 0, Box Tx 1, Box Rx 0, Bsi 0 Thank you , BR CArlos |
03-06-2006, 21:29 | #10 (permalink) | |
Member: 9290 Status: Offline Sonork: 100.57287 Thanks Meter: 35 | Quote:
Try to unplug the adapter from box then check pin 1 and pin 10 on box connector it is ok. If someone plug the 8 pin cable without adapter to box then pin 1 and 10 go down and there can't be good connection when plug 10-8 pin adapter to box. In this case Nokia phone has no VBAT and can't go to Local mode. | |
03-07-2006, 00:55 | #11 (permalink) |
Member: 115106 Status: Offline Thanks Meter: 4 | thank you once more for your help Now I have try .............. an 6230 , same , I use same cable with JAF and UFS , and it´s read the phone . So the main problem is .......... or the adaptor or the box ( I don´t think the problem is the box ) So the day after tomorrow I will try my friend adaptor . thank for your time ....... and I will tell you what is the problem BR Carlos |
03-13-2006, 16:27 | #13 (permalink) |
No Life Poster Join Date: Nov 2004 Location: In a Ganja plant! Age: 38
Member: 91298 Status: Offline Thanks Meter: 6 | I had this problem, I cleaned all the contacts on the RJ45 connectors (male and female) of the MT-Box, the adapter and the cable. After this it works fine. |
03-14-2006, 09:51 | #14 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Computer Age: 41
Member: 154696 Status: Offline Thanks Meter: 16 | i got the same problem. Any solution please ! The phone can switch between localmode, testmode and normal mode but can flash any thing. Always show this error msg: " Phone is in: Phone is not responding, power on phone! ". I try to read ask then this msg appear "Boot... ASIC ID: 0000 PHONE Tx not 1 Failed to read, error:" Any ideas please ! |
03-18-2006, 12:35 | #15 (permalink) |
Crazy Poster Join Date: Feb 2005 Location: Dakar Age: 42
Member: 115350 Status: Offline Thanks Meter: 2 | same probleme Salam i got the same problem. ============= Set Flash mode for info ============= Pins: Mbus 0, Box Tx 1, Box Rx 0, Bsi 0 Boot... ============= Set FBus mode for info ============= Pins: Mbus 0, Box Tx 1, Box Rx 0, Bsi 0 -------------------------------------------------------------------------- Where is probleme? Best regad, oumar_gsm |
I not know how to work with sagdd box . | mileta5 | SAGEM JTAG UNLOCKER | 8 | 02-20-2009 11:49 |
I need to know how to flash my nokia 6265i cell phone PLEASE! | fallonfallon7 | Nokia CDMA | 0 | 02-20-2009 03:14 |
My MT-BOX NOKIA can't flash phone HELP | wgmmmx | MT-BOX | 18 | 09-14-2008 17:12 |
how to get my mt-pro box reset | Mr Twitch | MT-BOX | 15 | 09-03-2007 09:46 |
My MT-box NK can't detect phone. | egidijus | MT-BOX | 1 | 03-19-2007 10:07 |
