09-16-2006, 10:11 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Location: romania-bm Age: 40
Member: 174315 Status: Offline Thanks Meter: 123 | nk 6680 problem hi, i had flashed one nk 6680 and after flash..phone power on but stops on nokia logo...sometimes it shows startup failed sistem error. i had done file sistem format with phone in local mode and browse..it had readed all info and i had done low, down full and quick format but still same problem. the phone was working fine..just needed to do fw update. i had used mt nokia box v1.23 and flash file RM-36_dp_v_8[1].00_MCUSW5.050407_EURO the phone is flashin ok with no errors and also factory set is ok. any sugestions? |
09-16-2006, 17:30 | #2 (permalink) | |
No Life Poster Join Date: Oct 2005
Member: 194868 Status: Offline Thanks Meter: 26 | Quote:
Flash phone with latest firmware virsion, your phone will be ok. | |
09-18-2006, 08:24 | #3 (permalink) |
Member: 174315 Status: Offline Thanks Meter: 123 | i tried with latest but didn't worked...the file sistem formnat wasn't done right by mt box...i had more 6680 which i had flashed and from 5 pieces only 1 worked...problem was solved using jaf... so please take a look griffin team on this |
nk 6680 flash problem | boy7000 | Nokia Hardware & Hardware Repair | 6 | 09-04-2007 18:48 |
nk 6680 n 7610 keypad jam need help ! | Brother Hui | Nokia Hardware & Hardware Repair | 3 | 04-09-2007 12:49 |
NK 6680 Flashing Probelm With Nbox+HWK Box | ccw123 | HWK | 1 | 11-07-2005 18:16 |
