04-27-2007, 23:58 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | Nokia 1112 can't stable on local mode help me to unlock my Nokia 1112 Phone is in: Normal mode Model: RH-93 ( N1112) V 6.00/24-10-06/RH-93 (c) NMP Production serial number KOA430970 Product code 0549302 Module code 0203167 Basic production code 0532665 Flash code Order number Long production SN MCU SW V 6.00/24-10-06/RH-93/(c) NMP HW 0536 PCI UEM 2339 UPP 8705 RFIC 0500 DSP P05w06.v34 LCD SDI:SYRS00 PPM V 6.00/24-10-06/RH-93/(c) NMP/IL ADSP SW p%V 6.00\n24-10-06\nRH-93\n(c) NMP\nil IMEI: 355514015448xxx Phone is in: Normal mode Imei: 355514015448xxx FAILED, check cable |
05-02-2007, 09:56 | #5 (permalink) |
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | YES It was cable problem and now ok. I want to ask you is it free to unlock 1112 V 6.00 ? Please give step to do it It is locking to Celtel Madagascar Thanks |
05-02-2007, 10:07 | #6 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 305905 Status: Offline Thanks Meter: 9 | yes its free ,check first the version of your pone then put the same version as you read to mcu in ppm,,then just click the patch sim and wait to finish ,and its all done phone is unlock,,,,note,,,no need to flash if you have the same flash file but you dont just flash the phone with any version after that just click patch sim and it will be ok |
i did every thing but those two 6210s not stable in local mode | summer_20xx | Nokia Base Band 5 ( BB-5 ) | 6 | 05-28-2009 19:16 |
Nokia 3500 Classic can't put in local mode | tio dan bilqis | J.A.F. By Jafsupport.com | 3 | 07-10-2008 10:30 |
1112 not going into local mode | SilentKiller | MT-BOX | 2 | 01-19-2007 12:59 |
6600 can't put in Local Mode | wiky | WD2 & APE (Symbian Phones) | 8 | 10-27-2004 07:56 |
