04-20-2007, 08:27 | #1 (permalink) |
No Life Poster Join Date: Sep 2002 Location: mauritius
Member: 15162 Status: Offline Thanks Meter: 61 | Nokia 6060 flash ok but not power on Have one nokia 6060 when flash it with cable it does not flash but it display local mode. When use easy cable i can flash phone but after flash phone still same problem.it power on white lcd then power off. But i can read info unlock etc... Have just latest flash file aso same problem .can anyone help me please VPP is DISABLED. Processing File: rh73_74__5.110 Boot... ASIC ID: 2031 DCT4 u_2nd.fia u_amd.fia 84F038093EDAC159487380566225 Configuration Info (9F): Number of Flashes: 2 01000000: Amd, 0001 2C7E 0035 7021, 11 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[10.00 MB]... erasing region [01000000 to 0101FFFF] erasing region [01020000 to 0187FFFF] erasing region [01E60000 to 01FDFFFF] in 75.34s Flash[7.41 MB]...in 45.00s * * Processed file in 128.75 seconds Processing File: rh73_74__5.11.image_a Boot... ASIC ID: 2031 DCT4 u_2nd.fia u_amd.fia 842C8ACA4BC4C87EE5B3F0A4DE9C Configuration Info (9F): Number of Flashes: 2 01000000: Amd, 0001 2C7E 0035 7021, 11 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[3.25 MB]... erasing region [01B20000 to 01E5FFFF] in 24.09s Flash[1.75 MB]...in 9.77s * * Processed file in 42.31 seconds Extract content...fail Processing File: rh73_74__5.11a Boot... ASIC ID: 2031 DCT4 u_2nd.fia u_amd.fia 8427E53D18235BFB490532601CA5 Configuration Info (9F): Number of Flashes: 2 01000000: Amd, 0001 2C7E 0035 7021, 11 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[2.62 MB]... erasing region [01880000 to 01B1FFFF] in 19.14s Flash[1.75 MB]...in 10.39s * * Processed file in 38.20 seconds * * * Phone flashing done in 4:33 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... V 5.11/30-05-06/RH-73 (c) Nokia. IMEI: 3******** Factory Default Settings...OK |
04-24-2007, 08:21 | #7 (permalink) | |
Freak Poster Join Date: Apr 2004 Location: Islamic Republic of iran Age: 49
Member: 64065 Status: Offline Thanks Meter: 5 | Quote:
* * Processed file in 42.31 seconds Extract content...fail for resolve this problem : 1. flash with latest software & firmware version after flash read full log if all ok phone must power on ok 2.if Extract content ...fail return from box try to use other image file manually before write a topic reed log all user and U not see : * * Processed file in 42.31 seconds Extract content...fail ha ha ha !!!! | |
04-25-2007, 07:41 | #9 (permalink) |
Member: 15162 Status: Offline Thanks Meter: 61 | Phone is in: Normal mode Model: RH-73 ( 6060) V 5.11/30-05-06/RH-73 (c) Nokia. Production serial number XD0240307 Product code 0530012 Module code 0202716 Basic production code 0523462 Flash code Order number Long production SN MCU SW V 5.11/30-05-06/RH-73/(c) Nokia. HW 0507 PCI UEM 1314 UPP 8241 RFIC 0500 DSP P05w19.v25.1.1 PPM V 5.11/30-05-06/RH-73_74/(c) Nokia./A IMEI: 3*********** VPP is DISABLED. Processing File: rh73_74__5.110 Boot... ASIC ID: 2031 DCT4 u_2nd.fia u_amd.fia 84F038093EDAC159487380566225 Configuration Info (9F): Number of Flashes: 2 01000000: Amd, 0001 2C7E 0035 7021, 11 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[10.00 MB]... erasing region [01000000 to 0101FFFF] erasing region [01020000 to 0187FFFF] erasing region [01E60000 to 01FDFFFF] in 78.22s Flash[7.41 MB]...in 43.17s * * Processed file in 130.99 seconds Processing File: rh73_74__5.11.image_bj Low level format...OK Boot... ASIC ID: 2031 DCT4 u_2nd.fia u_amd.fia 842C8ACA4BC4C87EE5B3F0A4DE9C Configuration Info (9F): Number of Flashes: 2 01000000: Amd, 0001 2C7E 0035 7021, 11 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[3.25 MB]... erasing region [01B20000 to 01E5FFFF] in 25.22s Flash[1.75 MB]...in 10.02s * * Processed file in 51.31 seconds Extract content...OK Processing File: rh73_74__5.11r Boot... ASIC ID: 2031 DCT4 u_2nd.fia u_amd.fia 8406B846A3B110578A8B113FB1A6 Configuration Info (9F): Number of Flashes: 2 01000000: Amd, 0001 2C7E 0035 7021, 11 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[2.62 MB]... erasing region [01880000 to 01B1FFFF] in 19.78s Flash[2.57 MB]...in 15.30s * * Processed file in 43.70 seconds * * * Phone flashing done in 3:56 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... V 5.11/30-05-06/RH-73 (c) Nokia. IMEI: 359363001443521 Factory Default Settings...OK Phone is in: Test mode Imei: 3********* SIM Unlock Successfull same problem mate when power on it power on white screen then power off .when put on cable i can read info unlock etc.... |
04-25-2007, 10:22 | #11 (permalink) |
Member: 15162 Status: Offline Thanks Meter: 61 | same problem mate .have full erase completly ,flash phone,check phone will battery it switch on and off,reconnect easy flash cable write pm ,unlock ,recheck same problem. |
04-25-2007, 16:03 | #13 (permalink) |
Member: 64065 Status: Offline Thanks Meter: 5 | hello 1. your phone is a new brand ? maybe its a hardware problem 2.re hot flash IC and check board maybe your phone board its a other brand (6060V or ....)or phone is refreshed phone 3.before flashing phone , version of firmware what is ? 4.try flashing with fbus cable , or if using easy cable don't remove battery when flashing. |
04-25-2007, 17:07 | #15 (permalink) |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | i had same prob sometimes the pcb is different becouse they replace cover of phone anyway try to flash with n-box full flash...... If you have n-box conntact me i think that i can help you thn ofcourse we will post hear (reason to conntact me is for faster support) WBR Formingus |
Nokia 1110 FLASHING OK BUT NOT POWER ON.. | amit123 | Nokia Hardware & Hardware Repair | 31 | 01-04-2014 05:29 |
Help Nokia 3310 Flash Ok But Not Power On | sofiame2006 | Nokia Hardware & Hardware Repair | 20 | 01-28-2011 14:36 |
nokia 1600 and 1208 flashes ok but not power on | vinkle | Nokia Hardware & Hardware Repair | 3 | 08-19-2009 09:04 |
Nokia 2300 Flashing Ok But NOt Power On | Ankit Verma | Nokia Hardware & Hardware Repair | 0 | 05-31-2008 08:05 |
help nokia 3100 flash ok but not power on | sofiame2006 | Nokia Hardware & Hardware Repair | 7 | 09-24-2007 18:11 |
