Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Griffin Products > MT-BOX
Old 05-17-2006, 09:26   #1 (permalink)
Member: 224881
Thanks Meter: 9
SE K608i dead after unlock
Hi , i have unlocked the phone k608i with MT box with out testpoint ( I didnt know that may unlock only with TP), then i have got the shock !!!!! the phone is totaly dead, it couldn't swiched on .and when try to connect again with MT Box there is nothing??? Boot error 003.Also the battery is empty after this process and dont work with other phones.
What can i do, please Griffin Team??????????I want a fast reply because the *******r wait since 3 days.
Old 05-17-2006, 10:27   #2 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Thanks Meter: 35
If your battery is empty after this process your phone have HW problem.
The phone cant be dead after unlock, ic cant goes to boot then is hw problem.
Also unlock without test point is posible with New ARM inside v2.5
How to unlock the phone with New ARM inside you can find in user manual v2.5 (its included in same rar file)
Old 05-17-2006, 11:03   #3 (permalink)
Member: 224881
Thanks Meter: 9
Thank u for reply, but the phone was ok before unlock. why just after unlock it didnt work???? this is the question?? and how can i solve this problem!!!
Old 05-17-2006, 11:14   #4 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Thanks Meter: 35
Please explain what method you use TP, NoTP, NOtp2, then can explain how to reviwe it, also if is posible press ??? button and paste details here.
Old 05-17-2006, 12:00   #5 (permalink)
Member: 224881
Thanks Meter: 9
I used normaly unlock with out TP. it worked ok unlocked finished.
PRT=00000378
MCU=...
PPM=...
DEC=...
REP=...
IME=356841 00 443390
MOD=17
LNG=English
IMEI: 35684100443390
Lock codes:
NCK: 2945 2549
NSCK:4167 4761
SPCK:6769 6765
CCK: 6541 2303
PCK: 3505 7393
ESCK:6741 2205
Unlock codes:
NCK: 1449 7752
NSCK:6501 5323
SPCK:6349 4351
CCK: 7151 2709
PCK: 4561 8903
ESCK:2569 0343
USER:0000
and as i said after that, the phone is dead, it dosent work with any function and doesnt boot in any way.
Old 05-17-2006, 12:30   #6 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Thanks Meter: 35
Connect phone to cable without battery, press ??? button then attach battery.
Check battery pls.
Old 05-17-2006, 12:57   #7 (permalink)
Member: 224881
Thanks Meter: 9
I connect the phone with Battery and press ??? I got after 20 seconds Boot error 003.Then reattached Battery, i got the same. I connect with out Battery and press ??? nothing happend. I checked a new Battery and i got the same.
Old 05-17-2006, 15:44   #8 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Thanks Meter: 35
Boot error 003 mean no answer from phone. Without battery for sure cant detect the phone. Please open the phone and check it is phone connector ok, because on k6xx its very easy to damage it.
The phone cant respond only in 3 case:
- Phone hardware problem
- Empty battery
- Cable problem
k608i dead after unlock the rsa mobilemaster Cruiser Suite 2 09-22-2006 17:27
K608i Dead after Unlock ..::Mr999::.. SonyEricsson (USB-Smart) 4 08-07-2006 17:35
k608i dead after unlock without tp basim Sony Ericsson 5 03-24-2006 15:44
k608i dead after unlock SIXTUS Sony Ericsson 2 11-30-2005 07:47
k608i dead after unlocking & cid changing adam92se Sony Ericsson 2 11-27-2005 17:05
Page generated in 0.15585 seconds with 9 queries
