02-15-2007, 01:56 | #1 (permalink) |
Junior Member Join Date: Jan 2005 Age: 43
Member: 106143 Status: Offline Thanks Meter: 0 | strange problem with mtbox nokia flashing Processing File: rh9__04.010 Boot... ASIC ID: 1120 DCT4 u_2nd.fia u_amd.fia 84C2AC412D4E5D9033D2E128094D Configuration Info (9F): Number of Flashes: 2 01000000: Samsung, 00EC 22FA 0000 0011, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[7.94 MB]... erasing region [01000000 to 0100FFFF] erasing region [01010000 to 017EFFFF] in 57.41s Flash[5.26 MB]...in 27.17s * * Processed file in 93.33 seconds Processing File: cp_pB_04.010 Boot... ASIC ID: 1120 DCT4 u_2nd.fia u_amd.fia 84FED50F81D790C552C9C75F9912 Configuration Info (9F): Number of Flashes: 2 01000000: Samsung, 00EC 22FA 0000 0011, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[1.06 MB]... erasing region [01580000 to 0168FFFF] in 9.22s Flash[0.17 MB]...in 1.16s * * Processed file in 18.75 seconds Extract content...fail Processing File: rh9__04.01B Boot... ASIC ID: 1120 DCT4 u_2nd.fia u_amd.fia 84FED50F81D790C552C9C75F9912 Configuration Info (9F): Number of Flashes: 2 01000000: Samsung, 00EC 22FA 0000 0011, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[1.06 MB]... erasing region [01580000 to 0168FFFF] in 8.53s Flash[0.91 MB]...in 4.66s * * Processed file in 21.52 seconds * * * Phone flashing done in 3:17 minutes Post Flash serial tunning of phone.... For example 6030 is flashing OK. I reinstal windows- no effect new program fo mt-box (1,26 + 1,29.1) no effect on another comp with XP this same problem on comp with w2000 this same problem and the best- on my friend comp with XP SP2 (I have too with SP2) 3510i flashed OK. I changed USB cable, phone cable i used active HUB- no effect. My friend tornado have too problem on all my computers. Magic or somethings? |
02-15-2007, 16:20 | #3 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 409197 Status: Offline Thanks Meter: 75 | Try Do Disable Vpp From Menu And Solution Of Softmobile . If You Have A Problem With Cable And He Dont Have A Good Connection To Phone Soft Can Not Change Modes -local,test And Can Not Extract Content. When Phone Fleshes See The Lcd, After Content Flashed Phone Need To Go In Test Mode. If Not Then Problem Is In Cable Or One Of Middle Pins On Battery. Brgt |
Strange Problem With Chinese Nokia N82 | mukasa | Infinity-Box | 2 | 07-15-2008 09:23 |
N95 Flashing Problem with MTBOX | ownage | MT-BOX | 10 | 10-07-2007 08:10 |
Just try Flashing E90 with FBUS Cables with mtbox Nokia!! | bestncheap | MT-BOX | 0 | 08-13-2007 10:08 |
Attention! Strange problems with 3310 after flashing | roller | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-29-2002 03:27 |
