Siemens-Benq Flash Patching All about Flash patching/patches and Flash Modifications we can get it from here |
08-26-2004, 12:07 | #1 (permalink) |
Freak Poster Join Date: May 2003 Location: Tehran Age: 52
Member: 27936 Status: Offline Thanks Meter: 0 | Serious Compatibility Problem Between ANM & RAC after that when I want to turn off my phone, the shutdown process freezes at shutdown image. after I remove battery and insert it again, the phone goes back to it's normal state but some application menu functions that were not enabled now become active like Supernet. I think there's a serious incompatibility between new ANM and RAC patches. Last edited by hrfonouni; 08-26-2004 at 13:39. |
08-26-2004, 12:39 | #2 (permalink) |
Major Poster Join Date: Nov 2003 Location: Poland - Wrocław Age: 50
Member: 44512 Status: Offline Thanks Meter: 0 | I Had the same problem... Problem apear when you apply ANM2 patch with combine RAC ;If you also want to have Record All Calls function, ;APP default menu item is Profile1-Func14 (value=D0): 0x444C8C: FFFFFFFF 9AF141D0 Apear Error "Error creating file", after this, you cant access to MMC, shutdown freeze...you describe.. After modify ANM to ;If you don't want to have Record All Calls function: 0x444C8C: FFFFFFFF EA00124D after this ===================================== - when RAC prof 1_14 is enabled ANM prof 2_3 is disabled or enabled & Call filter is disabled SL records calls ===================================== - when RAC prof 1_14 is enabled ANM prof 2_3 is enabled & Call filter is enabled SL plays am.vmo and dont record messege - so only info ===================================== - when RAC prof 1_14 is disabled ANM prof 2_3 is enabled answering machine is working ... (somtimes shutdown) so we can - record all cals - enable answering machine with record message - enable answering machine without record message.... try this and write please Your experience.. ps We need help from Riza. ps Last edited by Pbrzuch; 08-26-2004 at 12:58. |
08-26-2004, 13:01 | #3 (permalink) |
No Life Poster Join Date: Mar 2002 Location: -[r0]- Age: 53
Member: 9891 Status: Offline Thanks Meter: 2 | Is there anybody (else) here who has no problem with those patches? It work with no problem in my phone. @hrfonouni and Pbrzuch: do you guys apply Assign Any Ringtone to Any number + blackList? If so, do you mind to UNDO them just for testing ? rizapn |
08-26-2004, 13:26 | #5 (permalink) |
Member: 27936 Status: Offline Thanks Meter: 0 | My experience: after undoing this: If you also want to have Record All Calls function, APP default menu item is Profile1-Func14 (value=D0): 0x444C8C: FFFFFFFF 9AF141D0 and applying this: ;If you don't want to have Record All Calls function: 0x444C8C: FFFFFFFF EA00124D 1- When both are enabled and ICF is disabled: RAC works fine ANM's answering note works but there's no Recorded file. 2- When ANM disabled and RAC enabled and ICF disabled: RAC works fine 3- When ANM enabled and RAC disabled and ICF disabled: ANM works fine 4- When both enabled and ICF enabled too: RAC works fine ANM answering note works but it can not record caller's message. |
08-26-2004, 14:09 | #6 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | Before continuing the discussion, I like to make something more clear. 1/ Do we talk about RAC patch published by DeadManS? --> If yes, then we are in the different way talking about the red car ... If no, then we can continue the discussion. What I mean with RAC is the function inside the ANM which do a similar function with RAC patch published by DeadManS (so, you must UNDO DeadManS RAC patch first) ... rizapn |
The Following User Says Thank You to rizapn For This Useful Post: |
08-26-2004, 15:23 | #7 (permalink) | |
Member: 44512 Status: Offline Thanks Meter: 0 | Quote:
after uninstall this patch all working fine misunderstanding So thx Riza for patience In the future Riza please change patch name ex. ANM+RAC its more clear or describe - uninstall RAC from Deadmans...etc One question yet, Do you working over new version ANM with recorded call indicator? thx for support ps | |
Diff between V200 & C100 Datacables? | angoraith | VLSI, Conexant, Skyworks and Old Models | 8 | 12-17-2003 19:30 |
Communication Software between 3310 & PC | callas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-01-2003 22:06 |
what's the difference between t190 & t191 ?? | genocite | Motorola ODM | 1 | 01-14-2003 22:15 |
Diference between fbus & mbus | gorasiberia | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 07-27-2002 03:21 |
No connection between Astral & PC??? | Mr.Who | Mitsubishi | 3 | 03-18-2002 05:40 |
