x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
12-04-2002, 23:56 | #1 (permalink) |
No Life Poster Join Date: Sep 2002 Location: max232 chip
Member: 16036 Status: Offline Thanks Meter: 5 | a35 call ended problem i was playing around with imei of phone,using logger,map. now the phone shows signal but cuts call,says"call ended" what can i do to solve my problem. thanks in advance |
12-05-2002, 23:31 | #6 (permalink) |
Member: 16036 Status: Offline Thanks Meter: 5 | finaly killed the phone!*!*!need help now the phone is gone dead,using all2/3 version software,i have tryed to rite imei back,back phone doesnt on. when i try to restore flash i get errors such as 1}ie_badld.-specified comport doesnt exist. then when i useworkshop i get error:wrong flash image size. can any1 plz give me step by step,i.e which blocks to tick etc thanks in advance |
12-07-2002, 04:56 | #7 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ..still in idle mode...
Member: 3900 Status: Offline Thanks Meter: 31 | write fubu with unisiemens and load map. But it's more advisable to restore the calibration data by flashing back the original eeprom if your eeprom backup is not corrupted... |
12-08-2002, 07:48 | #10 (permalink) |
Member: 3900 Status: Offline Thanks Meter: 31 | Check your mail. I've also attached the UniSimloader to get rid of "ie_badld.-specified comport doesnt exist" error. Just search for the all a3x/sl45 doer or mapmaker. |
12-09-2002, 03:11 | #12 (permalink) |
Freak Poster Join Date: Jun 2002 Location: North Pole
Member: 12869 Status: Offline Thanks Meter: 3 | I agree with you Nicku that 80% is hardware but I have recently noticed that every a35 I unlock shows this ! symbol and says called ended everytime I unlock it what could be the problem, I know its a software problem because phone was working before and after unlocking it has problem. |
12-09-2002, 07:49 | #13 (permalink) |
Member: 16036 Status: Offline Thanks Meter: 5 | trying unisiemens hi, thanks for help,im going to try solution sent by k-dix,then i will notify u outcome,the reason why i change imei cause f "!",does any1 know why this happens? thanks bye:0 |
12-09-2002, 09:29 | #15 (permalink) |
Member: 16036 Status: Offline Thanks Meter: 5 | hi krtko.i flash new bin,then eeprom,never turn on,and before that it did have !,so do u suggest i start hardware and change PA? and is it possible for a phone from software to get into a hardware problem? thanks byee |
I-mate JasJar Call Ended Problem.......! | MUNEEB_AKHTAR_RAZA | HTC & PDA WM( With Touchscreen) | 1 | 10-31-2006 18:32 |
call end problem with v3 with no sloution | darkblues | Motorola Hardware Repair | 0 | 06-09-2006 20:55 |
call end problem with v3 with no sloution | darkblues | Motorola P2k | 3 | 06-08-2006 16:54 |
6620 call end problem | OMBOSSMAN | Griffin | 5 | 02-22-2004 22:20 |
Motorola V60 Call ended problem???pls help??? | proxy_gsm | Motorola P2k | 0 | 09-04-2003 20:27 |
