x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
04-10-2003, 18:05 | #1 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Netherlands Age: 69
Member: 16473 Status: Offline Thanks Meter: 13 | A35 dead Regards, jeanfleur |
04-10-2003, 18:11 | #2 (permalink) |
Banned Join Date: May 2002 Location: GERMANY Age: 43
Member: 11549 Status: Offline Thanks Meter: 6 | @ hi all this solution for All Siemens Use All 3/4 Siemens Service v2.0.5 (cracked by Xak) 1. Load *.flx file 2. Select COM Port and mobile type 3. Check option "Write Flash" 4. Check option "Write IMEI" 5. Check option "Burst Mode ( 10% faster ) Now U are ready to flash the phone... 6. Press "Init Mobile" and follow the program instruction's Afther flashing U need to read LOG file from phone and create a MAP file... 7. Use "Siemens IMEI Writer, Version 3.00" <-- read LOG and make MAP file 8. Now use " Siemens IMEI Writer, Version 3.00 " <-- to write MAP file to phone Afther writing MAP file to phone, your phone is ready for calls... Now is "All Done..." Note: for all people who cant start SW, and if someone receive some strange messages like ( ...export to missing Kernel32.dll or COMCTL32.dll...) they need to reinstall windows 98 SE!!! Only then, they will be able to run SW ( All 3/4 Siemens Service v2.0.5 Note: U must allways check both options "Write Flash" and "Write IMEI", only in that case U will be update your phone with full (correct) flash and eeprom.... When U check option "Write IMEI" then SW will write eeprom to phone, only IMEI cant be upload to phone, because the calcualting algorithm is inside the DONGLE!!! [email protected] Regards to all, thx for Xak |
04-10-2003, 18:47 | #4 (permalink) |
Member: 16473 Status: Offline Thanks Meter: 13 | Thanks bob_gsm After repairing with All3/4 I have done what you wrote logging and mapping again. Wrong software again after this. Can it be that something is wrong with my Maxim dongle? Regards, jeanfleur |
04-10-2003, 19:05 | #7 (permalink) |
Member: 11549 Status: Offline Thanks Meter: 6 | write log in Phone Unlocking Codes & Maps section http://forum.gsmhosting.com/vbb/foru...php?forumid=88 |
A35 dead every 5 minutes | CellM@n | Siemens Hardware Repair Area | 0 | 06-11-2002 01:57 |
Repair A35 Dead Phone | s3nt4 | x1x to x45/x50 | 11 | 01-02-2002 05:00 |
A35 Dead...can u helpme? | wilcd | x1x to x45/x50 | 1 | 12-07-2001 02:16 |
Found A35 Dead solution after Ziemens 1.22!!! | nightxyz | x1x to x45/x50 | 7 | 08-28-2001 10:32 |
HELLLLP! A35 dead after ZIEMENS | trafix | x1x to x45/x50 | 12 | 08-26-2001 13:17 |
