x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
08-19-2004, 07:58 | #1 (permalink) |
Freak Poster Join Date: Sep 2002 Location: Slovenia Age: 48
Member: 15385 Status: Offline Thanks Meter: 9 | A50 half dead, only bzzz, help... I have this A50 and it was locked, so I try to unlocked it with cracked ver. of Martech 3.9 . everithing sims to go OK, but now when I try to turn ON the phone, nothing happend, phone only bzzzz ( once ). What happend, what should I do, is there any solution to fix that? Please help me ... Thanks in advance for any help or suggestion. BR, dejan |
08-19-2004, 08:12 | #2 (permalink) |
Member: 15385 Status: Offline Thanks Meter: 9 | Martech progs says... ERROR(03.04) ------------------------------------ Not correct SP-Blocks in EEprom. Probably EEprom area is damaged. ------------------------------------ 1) Upload correct EEprom... 2) Use "Repair IMEI" function. Where can I get eeprom for A50? thanks and br, dejan |
08-19-2004, 08:20 | #4 (permalink) |
No Life Poster Join Date: Apr 2003 Location: ROMANIA Age: 45
Member: 26714 Status: Offline Thanks Meter: 14 | lolo martech cracked works only for write flash not for unlock use freia am just unlock your phone if not working write a good flash and then unlock |
08-19-2004, 08:22 | #5 (permalink) |
Freak Poster Join Date: Jul 2004 Location: 0xDEADBEEF Age: 42
Member: 71246 Status: Offline Thanks Meter: 40 | Hi!! HERE i s eeprom for A50.Upload this eeprom and use freia10 to unlock(unlock funkcion/direct unlock no map saved/use original imei) Just delete .txt and unzip!! BR |
08-19-2004, 08:26 | #6 (permalink) |
Member: 15385 Status: Offline Thanks Meter: 9 | freia 10 I try it with Frei 10, configuration like this... Normal boot, speed 57600, Proces Low... but freia say "boot file is not accepted" Whats next? |
08-19-2004, 08:29 | #7 (permalink) |
Member: 15385 Status: Offline Thanks Meter: 9 | freia 10 Almost forget... I chose Direct unlock also save map and I write IME in " new emai " section and then press... use EEprom imei Is this correct? |
08-19-2004, 08:33 | #8 (permalink) | |
Member: 71246 Status: Offline Thanks Meter: 40 | Quote:
In misc funkcion/bootcore type> choose bootcore bug IF this type is again not accepted choose pached bootcore REGARDZ | |
08-19-2004, 08:42 | #9 (permalink) |
Member: 15385 Status: Offline Thanks Meter: 9 | To Randy_d4 Freia 10.... COMM_IsBootRunning : bootcode does not seem to be running COMM_LoadBoots : Waiting to power on the phone ... COMM_LoadBoots : phone is powered on COMM_LoadBoots : internal loader version is 01.00 SEC_BCDIMEIToNormalIMEI : invalid decoded IMEI COMM_LoadBoots : EEPROM IMEI (3) is corrupt COMM_LoadBoots : original IMEI is 35044653013928 (locked) COMM_LoadBoots : found SIEMENS A50 lg6 v4 (1) COMM_LoadBoots : flash ids are 002088BA [00000000] - BA20 COMM_LoadBoots : phone ids are BF66E429 [BF66E429] cmd_handlecommands : using original IMEI (35044653013928) COMM_UpdateIMEIBlocks : update is not accepted Invalid decoded imei? This eeprom file u gave it to me it is in fls... martech request bin, should I use some other program to upload this or what? thanks... |
08-19-2004, 08:46 | #10 (permalink) |
Member: 15385 Status: Offline Thanks Meter: 9 | getting better but not enough... I upload eeprom1 wit Freia 10 and it goes OK. Not the phone goes bzzzzz and blinking... Did I do anything wrong? Should I Flash it with winswup? |
08-19-2004, 08:48 | #11 (permalink) | |
BR | |
SE P800 dead, only bzzzzz, help! | pchelpsi | Sony Ericsson | 9 | 12-04-2006 13:34 |
Please help ... GD87 half dead | Alkapone | Panasonic | 5 | 04-14-2006 10:09 |
SX1 only BZZZ | pepik | E-Gold Based Phones | 6 | 03-02-2005 15:30 |
Siemens a50 half dead | asmax1 | x1x to x45/x50 | 2 | 08-13-2004 01:09 |
A50 is dead ... map need ... HELP ME!!! | yayi | Phone Unlocking Codes & Maps | 0 | 03-04-2003 22:28 |
